Cam shaft numbers
#271
Not too many miles on this yet but, I have to give credit to Chris Straub for the cam and his help in influencing the parts package. The specs are smaller than I was thinking but, it has terrific response already (sure to improve with tuning) and revs hard to the rev limiter at 6400. The cam does it all!
#272
and there we have it,,you selling them w/ the chinese junk heads you have.friggen conman
probably the 5 sets you sold us came from there.
you can't even install an intake and your using and reading a micrometer.why not give the real author of your info credit,you fraud.
Morel lifters come in boxes or Clamshells. All of my lifters except for the occausional custom set, had to get a customer a set of Bushing .903" with offsets for a Pontiac, then another customer needed double offsets for a SB Ford build and those came in the craft boxes, come in the clamshell. They have my PO on them from the order and they are all marked on the tie bars.
#273
conman,conman,conman,
talk all you want,the fact that YOU sold them and spec them,,and they failed to oil is a screw up by you.A good conman,always has an excuse and tries to talk intelligent.fact is,bullet designs your cams.
now go learn to change a spark plug and sell some chinese heads and lifters,,conman,
#274
see,I actually build engines and not just chevy bbc,,my personal dmax to take me into the 11's all at 7100lbs.
#275
#276
I design all of my own camshaft profiles and lobe selection, world championship winning cams .Generally I use Crane Cams for the majority of my stuff and always are ground with 8620 billet core with iron gear.
#277
Hey gutter I think most people are just saying bob knows why he's doing and to use him. Bob is a super nice guy and helps anyone he can. That's all, there's lots of intelligent people here. I did get to see what some on here where saying and are just trying to point people in a good direction. Mr madera from what I've learned hasn't had one fail or not make power. But we all know he's not the only one but helps this forum.
#278
And I still sell them today. I will give the customer the options he or she has on lifters then they can choose according to what they want to spend. Now it is up to the engine builder to check the tolerances. Lifter bore clearance is no different then checking rod and main clearance. If this is missed and the engine goes down then it is the engine builders fault.
This lifter is used by many cam companies today under their own name and is still one of Morels top sellers.
#279
http://www.johncalliesinc.com/produc...ProductNo=4606
see retard,,I buy an isky lifter and I never have a oiling problem,,I buy 5 sets from you and I mysteriously have a problem.100's of other salespeople lifters,no problem,,5 sets from a boob alcoholic and i have a problem,coincidence,not a chance.you sold us junk.
again,the conman strikes
#280
And I still sell them today. I will give the customer the options he or she has on lifters then they can choose according to what they want to spend. Now it is up to the engine builder to check the tolerances. Lifter bore clearance is no different then checking rod and main clearance. If this is missed and the engine goes down then it is the engine builders fault. .
If you have an order for a very specific part, and you send something else, its your fault. This is not politics where you can keep blaming the other guy for ever. You need to take responsibility for all your screw ups.
You sell unmarked lifters in unmarked boxes. WTF knows what they are. Morel,? chinese? and you post an invoice that says Morel. Big deal. I can make an invoice that says anything I want it to.
