Does prop slip increase or decrease with speed?  Top speed less than expected. >
Old 11-10-2014 | 08:29 AM
  #111
Budman, did you install the new pump and lines yet?
MILD THUNDER is offline
Old 11-10-2014 | 09:12 AM
  #112
Nope. Still need to get the right fuel pump rod for it. I have the stock one but afraid to run it even for a test for fear of damaging the cam lobe.
Did you guys see my questions from over the weekend?
I did manage to find some time to run it on the hose yesterday. I ran it up to around 3200 RPM and watched the gauge, and it stayed steady around 6 PSI. I know that's not a real test, but it's better than the 4 PSI I was seeing without the engine running. I would have loved to have run it on the water, but ran out of daylight. Today might be the last decent day before the damned "polar vortex" descends on us, but I have to work.
Thanks for all the advice guys - you know I will update everyone when I get this sorted out.
Budman II is offline
Old 11-10-2014 | 09:28 AM
  #113
How long did you hold 3200?
Cole2534 is offline
Old 11-10-2014 | 09:39 AM
  #114
Not very long. Less than a minute. Wish I could play hookey today and take the boat out - going to be almost 70. But we have people out on vacation already and I'm the only one running the show today. Such is life.
Old 11-10-2014 | 09:52 AM
  #115
SB
Fuel psi in neutral is meaningless, even at 15,000 rpm...LOL.
No fuel volume needed with no load. HP requirements are near nil.
Atleast the pump put out 6psi with alternator running vs the 4lbs without it running.
SB is offline
Old 11-10-2014 | 11:07 AM
  #116
Very articulate subject matter and more than you might want...
http://forum.grumpysperformance.com/...hp?f=55&t=1939
Pliant is offline
Old 11-10-2014 | 11:31 AM
  #117
Pliant, that should keep me busy for a while.
Anyone have a link to a good fuel pump rod? Trying to decide between the bronze tipped ones and the composite ones. Have seen a few having problems with the bronze ones mushrooming, but my guess would be that they are using Chinese junk to see that happen - much like the brass / bronze dist gears.
Can I plumb the mechanical pump in line with the existing electric pump and expect to see a change just for testing purposes, or is this asking for trouble? It would be easy to do - install pump and then just attache the AN lines that are currently connected together to the fuel pump.
Old 11-10-2014 | 11:32 AM
  #118
Kind of what I figured, SB, but just wanted to mention it. Might be running this thing in the snow this weekend.
Old 11-10-2014 | 11:37 AM
  #119
Bud I'd think that the mechanical pump would pull through the electric,acting as a booster. Good luck
buck35 is offline
Old 11-10-2014 | 11:53 AM
  #120
Starting to think that a sticky post for fuel systems similar to the one Arcticfriends posted for oiling systems might be in order. I am going to be looking for info on constructing a new tank pickup with 1/2 ID instead of the current 3/8", probably some kind of filter ahead of the pump is running electric, etc.
