Does prop slip increase or decrease with speed?  Top speed less than expected. >
Old 11-10-2014 | 12:01 PM
  #121
Bud, let me know if u want that pump.
Black Baja is offline
Old 11-10-2014 | 12:21 PM
  #122
Hey Black, I appreciate the generosity. I found the one that I was using before, and I think it is essentially the same - 6-valve pump with big ins and outs. Now I just need to find a bigger tank pickup. Still want to run the damned thing one more time and watch the fuel pressure to make sure that is in fact my issue. While I was fooling around with it I pulled the carb and upped the jet sizes from 76/86 to 78/89.
Budman II is offline
Old 11-10-2014 | 12:22 PM
  #123
Dropping a hose in a 5 gallon jug is definitely the quickest way to find out if restriction is the problem.
buck35 is offline
Old 11-10-2014 | 12:23 PM
  #124
Originally Posted by buck35
Bud I'd think that the mechanical pump would pull through the electric,acting as a booster. Good luck
Yep, but if the lines are the big restriction, it probably wouldn't matter how big of a pump I run or how many, it can only flow so much. Maybe I should just take BUP's suggestion and drop a 1/2 inch rubber line into a spare gas can with the mechanical pump.
Old 11-10-2014 | 12:25 PM
  #125
I really feel like I need to run this thing on the water one more time and watch the fuel pressure. If I could get away with it I would shut the phone lines off and duck out of the office. Sunny and 68* outside my window, and I can't do anything about it!
Oh well, could be worse - I could be unemployed and selling the boat.
Old 11-10-2014 | 12:51 PM
  #126
Take it out after work...
Old 11-10-2014 | 01:26 PM
  #127
I'll have to rig up a bow light for my twilight cruise at 60 MPH! That's the other thing that sucks about summer being over - short days and long nights!
Thanks for giving my thread all this attention and good advice, guys. We'll get this thing figured out eventually. In the meantime, I have plenty of stuff to keep me busy, but I'm still all ears for good information and suggestions.
Old 11-10-2014 | 04:16 PM
  #128
Budman, why is this pump on your XMAS list???
Attached Thumbnails Does prop slip increase or decrease with speed?  Top speed less than expected.-electric_fuel_pump_4_6_psi_oem_152_0584_1520584.jpg
MILD THUNDER is offline
Old 11-10-2014 | 04:17 PM
  #129
[QUOTE=MILD THUNDER;4211278]Found the specs on that pump after digging all over.
50GPH flow at 6psi?
[url]http://fme
That research put some light on the whole conversation...
50 gph @ 6psi is not even a theorectical minimum.. and with 3/8 line's
http://forum.grumpysperformance.com/viewtopic.php?f=55&t=1939
Assume a BSFC of 0.55 and gasoline at 6.25 lbs/gallon: BFSC Brake Specific Fuel Consumption
horse power x 0.55 = pounds of fuel burned per hour
example
600hp x .55=330lbs
330lb /6.25lbs per gallon=52.8 gallons an hour minimum fuel used.....keep in mind pumping loss thru the lines , inertial loads and heat can easily reduce actual flow rates by more than 50% so if you require 50gph your unlikely to meet demand with less than a 100-120 gph pump even with the correct line sizes[/b]
Pliant is offline
Old 11-10-2014 | 04:19 PM
  #130
[QUOTE=Pliant;4217176][QUOTE=MILD THUNDER;4211278]Found the specs on that pump after digging all over.
50GPH flow at 6psi?
[url]http://fme
example
600hp x .55=330lbs
Pliant is offline
