-   -   8' beam into 7'9" garage door (https://www.offshoreonly.com/forums/general-q/319934-8-beam-into-79-garage-door.html)
97FASTech 11-07-2014 09:55 AM
Just don't let this turn out to be one those "Here, hold my beer" moments!! LOL
Sydwayz 11-07-2014 09:58 AM
We need to find the pictures of the rotisserie that 'glassdave' made. It's in the Fiberglass & Paint forum somewhere. I'll ask Dave if he can post it again if I can't find it in a minute.
Mr Maine 11-07-2014 09:59 AM
Watch this for pointers:
https://www.youtube.com/watch?v=fRuj4wChPtA
Realistically, I like the remove the door trim, maybe take the rubrail off if not too much work, should give you the 3 inches.
3pointstar 11-07-2014 10:10 AM
Originally Posted by Sydwayz (Post 4215559)
1) Pointy end first.
2) Speed*
*If at first you don't succeed; add more speed.
Don't forget the lubricant!
3pointstar
hadleycat 11-07-2014 10:37 AM
What is the distance between the 2 metal tracks the door rides in? If you can clear between them it shouldnt be too hard.
Most doors are trimmed around the inside of the opening with a 2x6. Then a 2x4 is nailed on the flat on the interior of the buiding. the edge of the 2x4 is held fush with the inside of the opening / 2x6. If you can remove the door weatherstrip then remove the 2x6 then notch the 2x4 you may make it work. If you have metal trim of course you will have to remove that first. Really not as bad as it sounds.
Reassemble with screws so it will be easy to take apart again.
phragle 11-07-2014 10:41 AM
Sell boat, buy a 24x7
Budman II 11-07-2014 10:41 AM
Originally Posted by Dads Nuggets (Post 4215547)
Does anyone have any clever ideas as to how I can get mt 8' beam boat into/through my 7'9" wide garage door? Plenty of room once it's through the door but??? Tilt on side maybe? Anyone ever done this?
Um, is this a trick question? I always hated those back in elementary school!
I guess there's always a way to do the impossible, but sometimes isn't it just easier to put it somewhere where it fits? (The boat, that is!) ;)
http://richardwiseman.files.wordpres...round-hole.jpg
buck35 11-07-2014 12:00 PM
Take a string 8 feet long, see how far you must raise it to clear sides, if you have the headroom build a ramp for one side and carefully back in.
Sydwayz 11-07-2014 12:01 PM
Check this thread out:
http://www.offshoreonly.com/forums/g...s-graphic.html
Perhaps you could rig something like this up to do this on your own trailer?
BUT, if you plan on installing the motor/drive and other stuff while it's inside over the winter, how do you plan to get it back out?
Black Baja 11-07-2014 12:18 PM
Sounds like a good excuse to build a bigger garage.
