Another build dyno'd today. Whippled 509. >
Old 01-20-2015 | 01:28 PM
  #31
does this challenge traditional thinking about the bang for the buck method of growing hp?
Forced induction versus NA heads, cam intake?
Seems like the value may be better with a whipple?
BTW what octane was the motor running?
stimleck is offline
Old 01-20-2015 | 01:30 PM
  #32
Originally Posted by stimleck
Mike how will you check afr's on a carbureted engine?
O2 sensors in the tails, or on each runner of the dyno header.
BP 93 for fuel.
Cole2534 is offline
Old 01-20-2015 | 03:00 PM
  #33
Originally Posted by Cole2534
How much length does the Whipple add to the engine? My compartment is TIGHT.
Cole, I think I read 11/2 to 2 inches. Yes very tight if yours is set up like mine.
buck35 is offline
Old 01-20-2015 | 03:15 PM
  #34
One things for sure. You ain't gonna see 800+ft lbs out of a N/A pump gas 509 at 3000rpm. I don't care how small of oval ports you use lol
MILD THUNDER is offline
Old 01-20-2015 | 03:27 PM
  #35
Rookie's Avatar
Impressive #'s for sure. Is the 2000RPM gap between peak TQ and HP normal? That seems like a lot.
Rookie is offline
Old 01-20-2015 | 03:38 PM
  #36
I've never seen it with a roots blower. Maybe Eddie young will chime in I know he's done plenty of builds with these small Whipple's
Old 01-20-2015 | 04:03 PM
  #37
Sounds like it needs more carb. The motor started to swallow the boost by the end of the pull.
Black Baja is offline
Old 01-20-2015 | 04:24 PM
  #38
rmbuilder's Avatar
MarineKinetics
Rookie,
We see 1800-2200 quite often on the forced applications.
Bob
rmbuilder is offline
Old 01-20-2015 | 04:33 PM
  #39
the carb and spark arrestor are both to small,i mentioned it earlier in the thread.the boost was going away because the 2.3 is really to small for this size engine.
mike tkach is offline
Old 01-20-2015 | 04:36 PM
  #40
it has been my experiance that the screw blowers start making the torque at a pretty low rpm.
