Carb opinions 540's 700 hp... >
Old 03-20-2015 | 07:41 AM
  #91
SB
The big advantage of not having a choke tower is when you have a shorter height flame arrestor / air cleaner.
In other words, those that have a short FA/air filter height and a choke tower are the one's really being hampered.
Remember, the choke tower is inside the FA/air cleaner housing.
SB is online now
Old 03-20-2015 | 08:17 AM
  #92
Knot 4 Me's Avatar
Mill the choke towers off of 4150's. We get by just fine here in the Midwest with no choke.
Knot 4 Me is offline
Old 03-20-2015 | 08:28 AM
  #93
He doesn't want to lose his picnic table of a hatch, and I don't blame him. Gotta be a way of fitting it under there Tim!
frickstyle is offline
Old 03-20-2015 | 08:39 AM
  #94
Full Force's Avatar
Most likely gonna have to find best 4150 option.... I am not modifying hatch....the Donna woukd force me to run 2" tall FA that's not gonna work
Full Force is offline
Old 03-20-2015 | 08:41 AM
  #95
vintage chromoly's Avatar
Originally Posted by 64294501
Tim do yourself a favor and listen to Rob and call Dale!!!!! It is a no brainer period !
Yo billy!
When you guys dynoed your engines with the CFM carbs, how did they work with the base settings?
I thought you guys put a mid dyno call into Dale for some fine tuning instructions.
vintage chromoly is offline
Old 03-20-2015 | 08:43 AM
  #96
Full Force's Avatar
Ignorant question here. Can you not replace the surface area of the screen with width instead of height? "Bigger Oval" arrestors instead of the tall "stack" type? (Think dual arrestors, compared to single carb style). I see one issue with airflow having to travel a longer horizontal distance, and then down into the carb, versus a more direct flow with a taller style. Is it really that much difference?
I had a couple people tell
Me you need 3.5-4" talkjg for proper airflow into the carb so the raised height of a dominator would cut that in half
Old 03-20-2015 | 08:48 AM
  #97
Here's the 4150 Dale built for me tim. It, most likely a complete piece of trash.
The first thing he said was, " nothing I can't fix with a 1/4" drill bit and a battery drill"! That's when i knew I was at the right shop!
Old 03-20-2015 | 09:14 AM
  #98
The last dealing I had with my carb builder was I was trying to tell him what it was doing and he was trying to tell me my cam was too big! I told him I was not going to tune the cam to the carb. You can guess how that went.
fbc25el is offline
Old 03-20-2015 | 09:23 AM
  #99
Check out these generic one size fits all junks ....best thing you can do with these is bring them to a real carb guy and have them drill some holes in random places for a large fee ...then they'll run great.
Attached Thumbnails Carb opinions 540's 700 hp...-fx-471111501.jpg   Carb opinions 540's 700 hp...-img_2901.jpg   Carb opinions 540's 700 hp...-quick-fuel-fx-4711-qfx-1150cfm-dominator-w.jpg
MILD THUNDER is offline
Old 03-20-2015 | 09:29 AM
  #100
More shelf 4150 junk...
Attached Thumbnails Carb opinions 540's 700 hp...-0e206b3d-bcd6-4652-a0b5-393af88c06b6-3918-000003056b0b90a7_zpsb4537654.jpg   Carb opinions 540's 700 hp...-qft-q-950_w__78958__19331.1405389402.1280.1280.jpg   Carb opinions 540's 700 hp...-idle-bypass.jpg
