Who has had issues with afr heads?? >
Old 05-31-2015 | 10:30 PM
  #51
Full Force's Avatar
Originally Posted by mike tkach
tim,never buy a lottery ticket,they will call you and say you owe the winner his money.man you have bad luck.
You and I have had many conversations lately, you know what I put into this and plain and simple some was just not my fault, guys on Oso only see what I post, makes me look dumb maybe but I am not at all, just bad luck haha oh well all I can do is fix it!!
Full Force is offline
Old 05-31-2015 | 10:31 PM
  #52
14 apache's Avatar
Originally Posted by full force
you can clearly see the difference in springs when you are looking for it...
I am in no way trying to bash afr or any person, not at all....
I am posting because you guys gotta look closer i guess at bolt on ready heads because although everyone's telling me i am the issue and there are tons of afr and other brands with no issues out there, it can happen is all i am saying, sorry guys pics don't lie, gauges don't lie... I got the one and only set or sets if issues, could have been a bad day for me i don't know but clearly i am saying check heads before bolting on simple as that.... Lesson learned .... The hard way... That's normal for
me.
[attach=config]541677[/attach]
wow
14 apache is offline
Old 05-31-2015 | 10:32 PM
  #53
Full Force's Avatar
Originally Posted by 14 apache
I may not of read that you pinned it to a lifter being stuck. I may be reading it wrong but the rookie and the stupid I am not calling just want to see why it failed and learn something.
Learned there was a miscommunication of what actual lifter to bore clearance is acceptable... .0012-.0015 is NOT, especially with 60 degree lake water... Let's just say I was with my machinist today opening up and honing lifter bores, and other engine will be coming out and apart it looks like just to make sure.
Old 05-31-2015 | 10:34 PM
  #54
Full Force's Avatar
Again I am not trying to make trouble for AFR or anyone else just facts, AFR is working with me to resolve the issues at hand and I know they will make it right and I will for sure buy afr again for future engines, my cobra has maxed out heads it needs afr on it lol
Old 05-31-2015 | 10:39 PM
  #55
14 apache's Avatar
You have bad luck hope it turns around pulling motors apart that aren't broke sucks,
  #56
Full Force's Avatar
If I didn't have bad luck I would not have any....
Old 05-31-2015 | 10:42 PM
  #57
better than pulling out motors apart that are broke imo!
mike tkach is offline
Old 05-31-2015 | 10:46 PM
  #58
Full Force's Avatar
better than pulling out motors that are broke imo!
Well I am doing both, I can tell ya it sucks more when broke !!!
Old 05-31-2015 | 10:53 PM
  #59
14 apache's Avatar
That's very true. Had something like this happen with a bad efi tune up killed a piston in one motor and detonated the other motor stuck all the second compression rings. the motors only had about 3Hrs on them.
  #60
You should have your machinist check the valve jobs while he's at it.
MILD THUNDER is offline
