A/f 540ci n/a >
A/f 540ci n/a
A/f 540ci n/a
Old 06-25-2015 | 09:25 AM
  #31
Full Force's Avatar
Yes egt plays a huge role not bad to monitor I plan to add later when I make more $$
Full Force is offline
Old 06-25-2015 | 10:08 AM
  #32
Originally Posted by ICDEDPPL
Hopefully they no longer get wet with new exhaust.
Apache , figured taking the reading from just one might be useless but figured its better info than nothing, I will take it with a grain of salt.
Those came out sweet!!! Maybe I can have your guy dip my manifolds this winter?
You ended up using the tails? Cool, spent some coin getting those polished, glad you could use them.
frickstyle is offline
Old 06-25-2015 | 10:16 AM
  #33
So why would you lock the timing? This is new to me so I truly don't understand the benefits of it, if any. It seems like total advance is what you're looking for and the curve to retard it at idle was to protect the motor/help idle, to be simple about it.
Baja Rooster is offline
Old 06-25-2015 | 10:34 AM
  #34
Full Force's Avatar
Takes out the crap idling when you have a distributor that gets hung up, its not a must but it's easier to not have the issues, I never had issue having it locked out
Old 06-25-2015 | 11:32 AM
  #35
Do u run the start/retard timing boxes? Mine are locked at 34 and pull 20deg out for starting.
endeavor1 is offline
Old 06-25-2015 | 11:43 AM
  #36
Full Force's Avatar
No boxes I never had issues starting them
Old 06-25-2015 | 12:18 PM
  #37
Full Force's Avatar
I guess in my case I never messed with what works
Old 06-25-2015 | 01:31 PM
  #38
really cleans up the idle with more aggresive cams and carbs, allows lower idle speed and your drive will love you long time for it....
ezstriper is offline
Old 06-25-2015 | 01:33 PM
  #39
looks nice...is that the water dump across from 02 ? if so 02's not going to last long..
Old 06-25-2015 | 01:42 PM
  #40
Full Force's Avatar
Still jacketed there
