THRU-THE-HULL water pick-ups >
Old 09-15-2002 | 02:56 PM
Default THRU-THE-HULL water pick-ups
When someone does a set of TTH Water pick-ups. The hose from the outdrive that used to bring the water to the sea strainer or sea water pump........that hose is cut and then attached to the TTH water pick-up. What happens to the hose on the outdrive end?
enticer is offline
Old 09-15-2002 | 05:11 PM
Smitty's Avatar
There is a fitting on the outdrive housing inside the boat that must be removed and replaced with a block-off plate. I have that plate if you need it.
Email me at [email protected] and I will see how much I need for it. It has never been used and I'll cut you a sweet deal.
Dave
Smitty is offline
Old 09-15-2002 | 06:13 PM
rbtnt's Avatar
You will need the plate on the inside as previously mentioned and you can cut the hose on the outside and just let the water run through the drive for cooling. I put a plug on the gimbal water inlet from the outside and drilled and tapped the side of my drive for a fitting and hose that I run to my billet drive cap.
rbtnt is offline
cougarman
12-05-2006 02:21 PM
waterbum
0
08-15-2005 10:36 AM
sejman
3
04-05-2005 04:53 PM
tomcat3
03-31-2005 11:50 AM
Maximus
04-30-2004 06:29 PM
