Engine Quest Head work results
#31
Really ? Damn. Got info on this ?
Some years ago I investigated and found they where being made at Masport Foundry in New Zealand.
Their website still shows this: http://www.masportfoundries.co.nz/head.html
And thus why I'd like to know if really now casted in China.
Masport Foundries Ltd make a range of V8 and V6 performance cylinder heads, in partnership with CompCams, which are sold under the RHS brand in the USA. In addition, Masport Foundries Ltd make a range of performance parts for other independent customers in both Australia and USA
#33
What sucked was the replacements were no better than the ones I had replaced.
#34
yes. A few years ago a friend won a raffle and the prize was a set of brand new rhs320 heads. They came direct from comp cams. I bought them from him, bare, and teh valve jobs were so bad on both heads i decided to contact rhs to see about getting them replaced. It took being persistent but they finally agreed. They were out of stock at the time so they had a pair sent to me direct from the machine shop which was royal oak boring in oxford mi. I still have the shipping receipt. It says under part name "bbc pro action china head".
What sucked was the replacements were no better than the ones i had replaced.
#35
What did you and your head guy think of the rectangle shaped exhaust ports?
Our heads are going to the machine shop to check/adjust the exhaust guide clearance a little. I must say, I was impressed with the port design of the EQ heads. I was a little thrown off by the rectangle exhaust port shape as I just expected it to be a D shape but overall they looked like a very good as/cast design to me.
#38
Those are good numbers. Back cut on the intake makes a huge difference in low lift numbers. I have a new set of EQ 320's here that I'm doing a valve job and blower marine prep. Staying with the 2.25 valve and not doing any porting. I may throw them on the flow bench just to see how they compare.
For Mild Thunder's comparison:
