High performance piston rings >
Old 04-29-2016, 11:00 PM
  #41
Originally Posted by 14 apache
My thoughts on zero gap is the ring pack will get loaded up with oil needs a little blow by to push the oil down where it belongs. And I have run them but I would not any more did not like them. Gap rings work perfect and they use less oil and the pistons and chambers look cleaner. Plasma moly for me.
the gapless and the gapped use the same oil control rings,the ring gap plays no part in oil control.
mike tkach is offline
Old 04-29-2016, 11:21 PM
  #42
SB
Received 3,117 Likes on 1,403 Posts
. Some very cool stuff and free beer at 6pm served by gorges girls. Lot of fun.
BEER IN HAND!
When in Pri was in Orlando, the free beer (packed in big coolers full of ice) was on all the buses that brought you to, from the Convention center from/to all the Hotels. No girls. LOL. Thought that was a nice touch.
SB is offline
Old 04-29-2016, 11:24 PM
  #43
SB
Originally Posted by getrdunn
Just had a thought that never dawned on me til now but last engine dyno'd we used sythetic. Ran into same issue a couple times before and typically would dyno with lighter weight conventional oil. Not saying for certain however anyone ever have same or similar with Molly rings? i believe it's certainly a possibility...
They (rings) usually say not to break in with synthetic.
SB is offline
Old 04-29-2016, 11:43 PM
  #44
i am pretty sure gm uses mobil 1 in all their high performance engines from the day they get the first fire up.i don,t think they ever see conventional oil ,at least not while they are in gm,s hands.also,the 392 in my srt challenger uses synthetic .i saw the equipment the big 3 are using to hone the cylinders with at the pri show,no independent shop could afford this equipment.the job it does is amazing,the tech is mind blowing.i remember in the 70s&80s 100000 miles on an engine and it was tired,todays engines are just getting broke in at 100000.efi,ring&honing tech has come a long way.
Old 04-30-2016, 06:07 AM
  #45
SB
Hard to say, all the vids I've seen in the plants show a cold run, and at the end before motor is crated it get's filled with Mobil one.
We need a line worker to respond. Do we have any ? LOL.
Anyway, as you said, how we assemble engines and what we use as parts can be very different from what the manufacturers do.
Here's a great vid on the Tonawanda engine plant:
https://www.youtube.com/watch?v=bLtZNtvc1Aw
SB is offline
Old 04-30-2016, 07:59 AM
  #46
yup,,because drunk guys will buy more stuff.
sutphen 30 is offline
Old 04-30-2016, 08:01 AM
  #47
are they using lasers like some if not most of the foreign companies?
Old 04-30-2016, 04:49 PM
  #48
14 apache's Avatar
Yes Budweiser and bud light the weather was much better but I think the show is better in Indy. I would rather be back in Orlando.
14 apache is offline
Old 04-30-2016, 07:47 PM
  #49
Sonic30ss's Avatar
Had that issue once, couldn't get rings to seat with synthetic , ran dino oil for a few passes and they sealed up.
Sonic30ss is offline
Old 05-02-2016, 06:12 AM
  #50
Much!
Originally Posted by ICDEDPPL
Is that better Todd?
teamsynergy is offline
