600SCI engine water Flow Issue >
Old 08-01-2016 | 09:34 AM
  #51
Originally Posted by buck35
I tried this spring but it was too large. Ended up finding a small diameter length of Dowling.
agree with sydwayz on the transom hose.
The rifle cleaner was to large? What is Dowling? Do you have the same heat exchanger as the 600sci?
bavboym3 is offline
Old 08-01-2016 | 09:39 AM
  #52
I think it was like 3/16 dowel. Mine was a 502 so it may be smaller, dunno.
did your flow issue happen slowly over time or come on fairly sudden
oops, I read what size dowel. Its wood turned. Think tiny closet rod.
buck35 is offline
Old 08-01-2016 | 09:41 AM
  #53
It came on very sudden. Been trying to find it ever since. Also i don't know what a dowel is
bavboym3 is offline
Old 08-01-2016 | 10:08 AM
  #54
Its possible the suction line is bad and collapsing internally.
I edited my last post , but dowel is just wooden roundstock, available at any craft store and most hardware stores.
buck35 is offline
Old 08-01-2016 | 11:40 AM
  #55
I got a rifle cleaner kit. Im going to give it a shot. Ill go from there I guess. This is my nightmare
bavboym3 is offline
Old 08-02-2016 | 08:47 AM
  #56
Was just reminded of another person with similar issue, turned out to be a clamp not fully seated or tightened allowing air to be drawn in as demand increased.
Having strainers l have to believe your issue is on the supply side of the pump somewhere if no impellers have grenaded in there.
buck35 is offline
Old 08-02-2016 | 09:02 AM
  #57
SB
Did anyone mention to check the water psi sender also ? They are in a brutal environment as they do not get filtered liquid like an oil psi sender does and they of same exact design and can go bad (plugged) easily.
SB is offline
Old 08-02-2016 | 09:07 AM
  #58
Sydwayz's Avatar
Forum Regulator
Originally Posted by Sydwayz
Follow your Fresh Water Flush (garden hose) connection hose as it heads toward your SWP. It will be in the line 1 1/4" hose from the transom assembly to the SWP. IF you have Sea Strainers, it will likely be between the transom assembly and sea strainer.
How did the rifle kit go?
No answer here on my above post. I can definitively tell you that I have seen water pressure issues on more than one Baja with their fresh water flush system getting gummed up.
Sydwayz is offline
Old 08-02-2016 | 12:59 PM
  #59
I cleaned out the heat Exchanger last night with the rifle cleaner. Nothing really came out. I also flushed water straight through, and water seamed to come out of every hole. No dice..
Still have to keep looking
bavboym3 is offline
Old 08-05-2016 | 11:20 AM
  #60
Replaced all the gaskets i could see. Still searching for the issue
bavboym3 is offline
