Originally Posted by bck
(Post 4488365)
If anything didn't check out it seems like that would be on Cam Motion since they do all the machining, hardening etc. What's the industry standard for hardening that you would be comparing them to?
From Harold Brookshire There is a limit to how far you can regrind a cam, or even the initial grind. Cams are made to a given lift, duration, and LSA, and then heat-treated, either carburizing (8620) or induction-hardening (other steels ending in -50 or higher). How long, and how deep, the heat-treat goes is very important. Many cams have only .080" or less of heat-treat. Cams can generally be ground +/-3* in LSA, and +/- .025" in lobe lift. These are the more important numbers. So this means you cannot regrind a .370" lobe lift, 106 LSA cam into a .450" lobe lift, 112 LSA cam. The grinding process with go through the heat-treat on both the nose, and on the sides. You can't grind a 106 LSA into a 108 LSA, then later try for 104, or 110. You'll go through the heat-treat. If you keep the LSA the same, or just a 1* difference, keep the lobe lift close to the original, you'll be much happier. The actual shape of the lift curve has more importance than either of those two....... I had also read, GM, had a spec of .180 deep when finished. |
The quote above mainly talks about regrinding and the risk of going through the hardening. These cams are new so regrinding through the hardening shouldn't be a concern. The video you posted shows them being hardened after grinding I think. Seems like Cam Motion is the only one that would really know if they are up to spec based on their manufacturing technique. Even if they are grinding them to someone else's spec I don't think they'd let them go with what they know to be a defect which is what that'd be. Mine still look good. We had the chance to check everything when we were swapping intakes.
(Post 4488378)
The quote above mainly talks about regrinding and the risk of going through the hardening. These cams are new so regrinding through the hardening shouldn't be a concern. I think the video you posted shows them being hardened after grinding I think. I'd think Cam Motion is the only that would really know if they are up to spec based on their manufacturing technique.
I might throw mine back in the dyno and play around with exhaust inserts in the collectors. I need to find someone who really knows exhaust to get involved with that.
Originally Posted by MILD THUNDER
(Post 4488382)
I could be wrong, but i don't think Cam motion, is grinding cam lobes, from bar stock. They probably get a series of lobe families, and have to grind off a certain lobe, to get their "custom" lobe. The cost, to manufacture a "one off" cam, from a blank piece of bar stock, manufacture it, heat treat it, then send it out, wouldnt cost 450 bucks.
Again after reading all this drama I'm so glad bob the cam numnuts didn't respond to my email. I could have pissed money in the wind like so many others. I'm sure he has a cam or 2 out there working. Even a blind squirrel finds a nut.
It to mention browsing cam motions site they are all about Ls series stuff. I'll stick with comp, lunati, or howard.
(Post 4488365)
I'd like to cut one of comps and one of bobs right down the middle length ways and dissect them. Just looking for answers. That's all. |
Other thing is you can run solid springs and rollers on comps hydraulic rollers years on end with no issues. Just saying and just wondering if.....
Originally Posted by jsand117
(Post 4487849)
Is there anyone out there that bought a set of MK cams and ended up with stout running motors that made good power??
| All times are GMT -5. The time now is 10:58 AM. |
