Custom cam thread >
Custom cam thread
Custom cam thread
Old 10-06-2016 | 11:17 AM
  #31
Full Force's Avatar
You Dyno?
I will post results when all is done I am just now tearing into this and won't be done for a while
Originally Posted by fbc25el
I have almost the same setup as you do. 540 -315 AFR heads. The cam is 246*-250* at .050 >663-.654 lift. 112 lc. Can you post what you replaced that MK cam with and what the result it made? I am going to rebuild and might make a change.
Full Force is offline
Old 10-06-2016 | 11:19 AM
  #32
SB
You have around 300hrs on your set up don't you ?
On paper, it looks like a great combo.
SB is offline
Old 10-06-2016 | 11:59 AM
  #33
Yes.It has. I have a bad habit of If someone is having a problem I think I will have it to. Its just me.
fbc25el is offline
Old 10-06-2016 | 12:02 PM
  #34
SB
It's human. Sometimes good,sometimes bad. LOL.
SB is offline
Old 10-06-2016 | 12:11 PM
  #35
Full Force's Avatar
Have to what?
Old 10-06-2016 | 03:04 PM
  #36
Hello, I have a set of 540's, I'm getting ready to recam, they are close to your second combo, but with Edelbrock heads. Any dyno numbers on this combo?
Thanks Sir..
Lack Of Assets is offline
Old 10-06-2016 | 03:26 PM
  #37
I should have clarified this thread. None of those camshafts, were picked by me. They were examples of what marine kinetics has specd for various builds, for comparative purposes.
MILD THUNDER is offline
Old 10-09-2016 | 01:39 PM
  #38
Here's my 468 recipe thanks to joe!
468 stock forged crank, forged rods
2399 Pistons
088 500hp heads
Crane 134561 cam.
Hyd flat cam @.050 236/246
.553/.571 lift
114 lobe sep
525sc blower and carb 5lbs of boost
Made 572hp at 5600
I think it was 650 tq
79formula is offline
