Valve seat materials >
Old 11-23-2016 | 09:17 AM
  #41
Originally Posted by Knot 4 Me
In reference to young guys and leaded fuel, I worked at a full service (yikes!) gas station back in the early 80's when leaded fuel was still available right next to unleaded. I can't tell you how many gas tank filler necks I modified to accept the larger leaded fuel pump nozzles and how many "test tubes" (anyone remember that name?) I installed. No one wanted to run unleaded even in cars designated for "Unleaded Fuel Only".
Or order the filler neck for a export model. Canada went unleaded later.
Interceptor is offline
Old 12-08-2016 | 12:21 PM
  #42
Anyone having problems with valves sticking in the guides?
gnorthga is offline
Old 12-09-2016 | 06:43 PM
  #43
What about valve seals can you leave them out to help with the oiling we keep having valve guide failures
gnorthga is offline
Old 12-09-2016 | 07:26 PM
  #44
With bronze guides .0013 intake .0018 exhaust. With iron heads .0020 you also need to have a nice wide valve job so the heat from the valve is transferred to the head and into the coolant system. If it's moderate performance I run all valve seals. If it's a really healthy motor I don't run them on the exhaust.
Black Baja is offline
Old 12-09-2016 | 07:28 PM
  #45
I also run two stroke oil 100:1 mix this really helps keep things a little more lubricated. You can see a big difference when you pull the motor apart.
Old 12-09-2016 | 07:35 PM
  #46
No valve seals on my engines No guide issues, haven't used them in 17 years
abones is offline
Old 12-09-2016 | 07:39 PM
  #47
Interesting...I used to run Amsoil 100:1 in my two stroke bikes back in the day but never thought to run it in anything else. Maybe I'll try it in my new engines what brand are you using?
Diamond Dave is offline
Old 12-09-2016 | 07:46 PM
  #48
What kind of valve guide clearance are you running? What cylinder head?
MILD THUNDER is offline
Old 12-09-2016 | 07:52 PM
  #49
Usually Pennzoil. Cause it's cheap. If I can't get my hands on two stroke oil. I'll dump transmission fluid in instead at 100:1 mix.
Old 12-09-2016 | 08:27 PM
  #50
And if you don't wanna go cheapest but smell good and get so e attention use klotz. If I could patened a men's cologne out of high octane and klotz I might have a faster boat. Hah
getrdunn is offline
