Bandit motors >
Bandit motors
Bandit motors
Old 01-02-2017, 08:05 PM
Originally Posted by endeavour32
I bought these engines from Tinkerer I have not dyno'd them myself and I don't think I got an RPM number from him. I know I was told to prop them between 5600-5900. I'm currently at 5600 and I'm happy there. When prop testing I started with 30 bravo's and spun them at 4800 RPM's. I ended up with 26 Bravos at 5600 RPM's. Speed gain for proper RPMs=0. I started at 80 and ended at 80 and I tested well over 5 different sets of props. The one thing I forgot to mention is I'm running 1.8 rockers on the intakes so that will change things slightly.
Did you see Mild Thunders post on all the various cams and the results? The best average power came from a 741 cam. I'll be honest, I was rather shocked at the results.
Yeah I saw that. Joe and I have talked extensively. He helped pick the cams I'm using. With my specs these were good for like 30-40 peak hp over the 741. That was at 6k and 741 was at 5500. I'll know full results soon enough as I hope to wrap these things up and dyno soon. Lol
Crude Intentions is offline
Old 01-02-2017, 08:46 PM
Originally Posted by leif
Anybody know these motors are they good built motors..looking at 510 ci 690 hp n/a..thanks for any input
i would think to make 690 hp from a 510 the compression would need to be 11.1 or more and rpm it to 6500 or more.
mike tkach is offline
Old 01-02-2017, 10:01 PM
scippy's Avatar
Bandit performance marine
If you're talking about Bandit performance marine here in Brick, nj........great reputation!
scippy is offline
Old 01-02-2017, 11:38 PM
they advertise a 700 hp 509 on their website but no information about c/r,type of cam.they do say aluminum 320 heads but no mention of the brand.they do say cam by crane.i sure would like to know more about this engine.
Old 01-03-2017, 05:30 AM
Full Force's Avatar
Me too, thats a big claim for the CI.
Full Force is offline
Old 01-03-2017, 06:08 AM
The Mercury supercat engines were 510ci. 750hp. They also were like 12.5:1, with a 280ish duration solid roller that revved to like 7500rpm with brodix cnc ported heads. Not a real pleasure boat friendly engine
MILD THUNDER is offline
Old 01-03-2017, 06:10 AM
I'd want to know what heads they are using, what compression ratio, and generel specs of the cam. It looks like they are using the profiler intake, so maybe they are using the Profiler 320 head, which is a good head but they don't mention a thing as to the brand. At at a bare minimum least I'd want to know where the engine makes its power.
IMO, there is no way they are building 700 hp out of a 510 CI engine. For comparison here are my engines which are 650 hp. 509 CI, Crane 741 cam, 10:1 cr, Dart Pro 1 310 heads (ported by Jim V to 320, it takes one hell of a head to out flow these, they flow 394 cfm @ .70), Dart intakes and holley hp 950 carbs. I'm sure there is a bit to be gained by going to a bigger carb, have the intake ported and bump up the compression a bit more. Either way I don't think there is another 50 hp to be found, maybe but I doubt it.
Those are some nice builds you have there. Cant go wrong with those JimV heads and a cam thats proven not to beat up parts.
Old 01-03-2017, 08:29 AM
So here is the Dyno sheet. Looks like a 651 cam, pro 1 310 heads, sniper jr intake. 1050 carb. No idea if it's a 4150 or 4500, due to the jets im guessing 4150. Either way, Dyno sheet guys, is this a happy Dyno or using a realistic correction factor?
endeavour32 is offline
Old 01-03-2017, 08:42 AM
^^^^^^^^^^^^^my head hurts trying to read that sheet.^^^^^^^^^^^^^^^^^^^^^6
Old 01-03-2017, 08:50 AM
Looks like a nice powerband to me . Nice to see a marine build that isnt falling on its face at 5500.
509, dart 310 heads, id imagine a healthy cam in it based on the powerband. Be nice to know more info on the rest of the build
Edit. Just noticed its a 651 cam. That is a healthy cam for a 509
