Afr heads with PAC 8002 spring upgrade.
#31
Im just hearing the same thing over and over again that's been talked about in other threads, post a link of the springs your using, not the ones you say are junk tell us what your moving forward with, springs, cams, heads, intake,carb, exhaust ect. spring will be here before you know it.
#32
I was not aware that you could get isky tool room springs shipped and installed with the afr heads ..thats a good thing
Our buddy got afr 315 heads from Bob. Upgrade to inconel valves, and #8002 spring "upgrade", which are the cheaper PAC springs. They were for a 1000hp forced induction build.
#33
It's not a bad thing, if you've got the coin go for it. A true set of endurance springs can be 6-800 per set but if it gives you piece of mind maybe it's worth it. Just make sure the lifters and the rest of the valvetrain are up to the task.
#34
#35
#36
#37
#39
i called joe b and he did not get any spring upgrade,even though i wanted him to get the isky tool room springs.he said his heads had the pioneer springs installed.the invoice copy you posted is to small for me to read but i am guessing it is joe,s.does it state what springs were installed on the heads?
Im sure tool room springs would have been alot more money. If i recall, the 8002 "blue stripe" springs, were pioneers. The 8002 "green stripe" were pac 1940.
