Another winterizing question >
Old 10-30-2017 | 06:37 PM
  #51
Originally Posted by Interceptor
fog engine
pull block drain plugs and poke openings to insure not caked with sand
pull manifold drain plugs
pull oil cooler drain plugs
pull lower hoses off engine
pull hoses off raw water pump
pull hull drain plug
drives neutral
remove batteries
raise front of trailer
cover and walk away, has worked for 18 years in northern Michigan cold indoor storage.
That's what I do. Also remove outdrives and spray oil down intake runners but he mentioned he couldn't get at drain plugs at beginning of thread. I have enough space to lay down in front of engines or over the top. He stated not enough space in his Nordic.
veloc410 is offline
Old 11-01-2017 | 08:56 PM
  #52
Drain all water from engine block , manifolds , coolers etc etc ... We put sterndrive into 110 gallon of -50 . Start Engine , spray fogging oil in engine while running . When antifreeze flows out exhaust , we quit . I've disassembled literally 100's of engines that have been fogged . If they werent fogged , they started flash rust on the cylinder walls in a matter of hours. We would fog all race engines after the race. If the tuner forgot , or wasnt able to , the cylinder walls would stain up , on the truck ride home.
dunnitagain is offline
Old 11-01-2017 | 09:01 PM
  #53
agreed. Nothing rusts faster in an engine than the cylinder walls. It is most delicate and suscetible part of engine👍👍
veloc410 is offline
