Another winterizing question >
Old 10-25-2017 | 11:52 PM
  #41
Originally Posted by veloc410
😀😂😃😃😄😅. Oh man. Anyway here is another way. I remove my outdrives every year. I start my engines without the outdrives on . Tap the plastic inlet suction hose fitting at gimble bell with 1/2 NPT about half of the thread deep. Home depot has brass garden hose to pipe fitting with either 1/2 npt or 3/4 npt. Put short length nipple on it and screw it in . Now a shortened garden hose will screw right into the fitting. Drop 1/4 HP sump pump into 5 gallon or larger pale . Have someone turn on pump start motor. Without T stats in. You can also use slightly heavier springs in checkballs to make sure antifreeze pumps into engine first.
Was just thinking bout this again. Heck you can run the sump pump right into the recirculating pump or cross over pipe and it would push radiator fluid right through th blocks, all the way up through the heads and out the exhaust tips.🤔🤔🤔 I'm likin that . The engine would be filled with radiator fluid
veloc410 is offline
Old 10-26-2017 | 05:07 AM
  #42
Pull the lower hose and drain block-heads as much as you can first. Guy I knew did essentially that. I helped him replace a cracked block the next spring. Running the motor does not guarantee you are replacing the water in block with antifreeze.
dereknkathy is offline
Old 10-26-2017 | 07:00 AM
  #43
This thread should be labeled how to make a simple job hard.
Unlimited jd is offline
Old 10-26-2017 | 09:33 AM
  #44
BUP
OR how close is the certified Mercruiser dealer away to do this job for my boat and they have all that liability to make sure all is correctly done.and fully protected for the winter.
BUP is offline
Old 10-26-2017 | 09:34 AM
  #45
I agree . Those water ports at front of block where water pump bolts up is much higher than base of block. Scary situation no doubt
veloc410 is offline
Old 10-26-2017 | 05:47 PM
  #46
If you have hard water you might wanna get to those block drains, hard water kills blocks. I have a Reverse osmosis system and soft water so I`m fine. Soft water is too soft to crack blocks.
ICDEDPPL is offline
Old 10-26-2017 | 06:02 PM
  #47
😀😂🤣😃😄😅 soft water
veloc410 is offline
Old 10-26-2017 | 06:12 PM
  #48
It does lower the freeze point that's one hell of a risk. No way would I try it. Don't care how pure the water is. It's water in a cast iron block. It's going pop that sucker wide open. I apologize couldn't help it
veloc410 is offline
Old 10-26-2017 | 08:21 PM
  #49
I think it still gets hard when it freezes...
Old 10-30-2017 | 05:59 PM
  #50
fog engine
pull block drain plugs and poke openings to insure not caked with sand
pull manifold drain plugs
pull oil cooler drain plugs
pull lower hoses off engine
pull hoses off raw water pump
pull hull drain plug
drives neutral
remove batteries
raise front of trailer
cover and walk away, has worked for 18 years in northern Michigan cold indoor storage.
Interceptor is offline
