milkshake or condensation
What gaskets are you using? I have had trouble with the FelPro High Performance gaskets in the past. Especially the intake gaskets. They are made of paper / cardboard. I like using a stock type intake gasket that has metal in it.
I’ve seen it that bad from condensation after a short jaunt in frigid water and oil temps never came up. That was with an oil thermostat as well. I pressure tested the cooling system to verify it was not leaking internally as I found it odd that both motors looked the same as yours do. Cleaned out engines and put T stats back in, went for long cruise to get block temps back up and never another issue.
Pressure check the cooling system (pita but can be done). Run the T stat and properly vent the crank case would be my suggestion.
