Water dumps
Old 07-24-2018 | 05:27 PM
couple things can cause high water psi. Depth of the water pickup on the hull, restrictions on water exiting the engine. Such as, thermostat, too small lines to exhaust, etc. Personally, before bleeding water off, i try to make sure there is no exit restriction. if there isnt, than I'd take a good look at the pickups, If they are thru hull, and mounted excessively deep, raise them/trim them. Having them deeper than they need to be, only to blow the water off the side of the boat , is a waste, and on some boats, can scrub a bunch of speed. The pickups on my fountain are almost even with the bottom like Vintage's .
MILD THUNDER is offline
Old 07-24-2018 | 07:08 PM
My pick up is on the drive.dravo 1 standard unit
warlocky is offline
Old 07-24-2018 | 07:36 PM
are you running the stock circulating pump or a crossover? If a crossover, what size is the bypass and lines going to exhaust?
Old 07-25-2018 | 09:11 AM
all stock stuff.side mounted water pump,running stock circulating pump.going to check my exhoust.pull the risers and see if there are stoped up.i have my water presure line in the block wher the side drain is.will that make a difference how the presure reads.
warlocky is offline
Old 07-25-2018 | 10:55 AM
I have a warlock 25 sxt with a carb 502.i have to much water presure.I put 2 dumps off the rear of the intake with values to controll the flow but the motor dosnt get enough water to the thermostate.where is the best place to put my dumps.Thanks.
keep bleeders at rear of intake, the ones you're currently using are likely too big and are bypassing too much water, -4 hoses will flow enough water out and away from rear cylinders. (typically the problematic area of BBC) and rid potential steam pocketing of rear cylinders, what is your water pressure at speed?
adk61 is offline
Old 07-26-2018 | 01:14 AM
That location works fine, but the hose may clog easily.. Thats where it was on my Pantera and clogged all the time. The ones on my AT are in the intake manifold and never clog.
Griff is offline
Old 08-28-2018 | 10:43 AM
I added a presure value to the intale line after my cooler.the hose was allready cut there.......got it set to the lowest possible rate.check all lines,exhoust risers are clean.move my presure line to the intake.i still peg the gauge.if my s pipes are to close to the exhoust will this raise water presure.i might cut the y pipes off to get them away from the riser pipe......can i get block off plates for a bravo 1 that draws water at the sides.
warlocky is offline
Old 08-28-2018 | 11:04 AM
Post a pic of your setup.............
payuppsucker is offline
Old 08-28-2018 | 11:51 AM
It wont let me post photos.
warlocky is offline
Old 08-28-2018 | 11:57 AM
warlocky is offline
