Holley Snipper >
Holley Snipper
Holley Snipper
Old 06-29-2019 | 08:21 PM
  #51
Update, lake level finally came down, ran the boat today for 3 hrs with no problems from the Holley sniper EFI, AFR's stayed as set seem ok at this time,
Regards
Texascuda is offline
Old 06-30-2019 | 09:58 AM
  #52
I`m converting mine, was going to do a whole how to thread but the powers at be made it difficult for me to post so **** you guys.. lol but have a nice day.
ICDEDPPL is offline
Old 06-30-2019 | 10:06 AM
  #53
F-2 Speedy's Avatar
Very nice ^^^^^ coil on plug also, you'll like it after the bugs are worked out
F-2 Speedy is offline
Old 06-30-2019 | 02:13 PM
  #54
Wow very nice I looked at my log and I have to adjust the TPS only getting 81% at WOT, did manage to get 63 mph on the GPS.
Old 07-04-2019 | 08:32 PM
  #55
I finally made it out for a few hours on the new engine and I can’t say that I miss playing with jets one bit. Set some parameters, run across the lake a few times, and done.
13.5 for idle.
12.8 for cruise.
12.5 wot.
I’m having an issue with getting the IAC below 20%, but a few minutes on the internetz oughta sort that out.
Baja Rooster is offline
Old 07-25-2019 | 02:15 PM
  #56
13.5 for idle.
12.8 for cruise.
12.5 wot.
If you haven't figured IAC yet, you'll probably need to do it in the software and burn to the ECU. The IAC is set by default to scale down to 0% at 160*, and you're probably not getting over 150*. I haven't actually done a sniper setup yet (I've only done megasquirt in automotive stuff), but I asked Holley this question directly and that was the answer (the question was pointed at sniper EFI - for sniper, the warm IAC curve can't be changed in the handheld screen, it must be done on the laptop with the tuning software).
Hoping to get this conversion done soon on my 454 mag, running sniper and a surge tank/pump combo.
FYI - I've had good luck with holley responding to all my technical questions, even before anything was ever purchased.
MTScott is offline
Old 08-12-2019 | 04:59 PM
  #57
Update: As of today 10 hrs on the motor runs fine the Sniper is working and and the added pipe inside the riser, seems to be keeping the 02 dry. Ran 63 on gps with 5 people and 70 gals of gas.
Old 08-12-2019 | 06:24 PM
  #58
Great info here. Can you give more detail about your application and any before and after comparison that you might have.Thanks
ph1971 is offline
