New cam setup >
New cam setup
New cam setup
Old 12-17-2018 | 06:30 PM
SB
Most Eliminators have them.Hard to find another manufacturer that has more crazy power installed in their boats.
SB is offline
Old 12-17-2018 | 06:50 PM
GPM
I'm not picking on anyone, anything, just thinking if the riser was long enough to dump at the 90, reversion would be a non issue. I could be wrong.
GPM is offline
Old 12-17-2018 | 09:09 PM
Originally Posted by Smoke eater
Are you guys thinking this is to much cam?
I quoted and was refering to Fingscreenname.
(288/294, Lift .585/.610, 112 L/S cam.)
your cam is just fine.
ICDEDPPL is offline
Old 12-18-2018 | 12:35 AM
Ooops...........didn't see that.
Griff is offline
Old 12-18-2018 | 01:55 PM
Being I have had the set up for 4 or 5 years now I can tell you there is no reversion issues. It has Merc 496 Aluminum manifolds and their SS risers. They are the tall of long version but that only means a 1/2" taller then the shorter ones. From there it all stays 4" and goes to the outlets in more of a pulled out "Z" pattern. In other words it don't double back on its self. All of it leans to the transom. It does have flappers on the tips. Nothing special but it works.
You can see the angle better in this picture,
f_inscreenname is offline
Old 12-18-2018 | 03:03 PM
I love the valve cover “Time Warp”
Smoke eater is offline
