Oil filter attached to valve covers LEAK >
Old 07-09-2019 | 01:41 PM
  #41
SB
Originally Posted by payuppsucker
Tried to PM SB but his box is full. He'll be back though.............
Nothing worse than full bad box.
SB is offline
Old 07-09-2019 | 01:46 PM
  #42
Mbam's Avatar
Offshoreonly Advertiser
For sure something is damaged. A healthy engine will have a light flow of air & vapor out the breather, not puffing smoke.
The volume in the crankcase does not change as the pistons go up and down. For each piston moving down there is one moving up. Any flow out the breathers is from combustion gases getting past the rings or piston.
https://www.aa1car.com/library/engine_blowby.htm
Just for grins crank the engine with the ignition off for a few seconds. You can tell by the sound when a leaky or dead cylinder hits the compression stroke. Once you learn that sound the only reason for a compression test is to figure out which one (or more than one) are hurt.
Mbam is offline
  #43
Originally Posted by SB
Can't answer that as it may or may not makes things worse. Your call.
When you get into the diagnostics and repair, keep us informed and ask as many questions as you fell like.
In the mean time, did the previous owner leave you with a detailed list of the engine build ?
Unfortunately no. According to him it was previously owned by a marina owner who absolutely loved the boat and bought it brand new and that's who did the full build on it. He only owned the boat for maybe 3 or 4 months and only put 2 hours on it before realizing his wife and 3 kids were a bad fit for this little boat so he sold it to me.
What further damage could I do exactly?? If the piston or pistons are already screwed, i assume it couldn't get much worse?? Maybe, well probably, I am wrong here.
PremierDetailer is offline
Old 07-09-2019 | 01:48 PM
  #44
Wally's Avatar
Were doomed!
If it were me id first start with a compression test...and if that doesnt point to one or more piston holes to look at i would then do a leak down test and make the call from there.......that smoke coming out of the valve covers reminds me of a steam locomotive! sorry dont mean to hit a guy if he's down....just making light of it
-Wally
Wally is offline
Old 07-09-2019 | 01:50 PM
  #45
F-2 Speedy's Avatar
whats the oil pressure ? sounds like a bunch of rockers rattling, I wouldn't run it till the valves are adjusted properly
F-2 Speedy is offline
Old 07-09-2019 | 01:54 PM
  #46
Gauge says its right around 70- 80 but that's rather hard for me to believe.
Old 07-09-2019 | 02:01 PM
  #47
F-2 Speedy's Avatar
when you started it in the video did you have water hose hooked to the engine ?
Old 07-09-2019 | 02:03 PM
  #48
I think the boat is in the water Ken.
payuppsucker is offline
Old 07-09-2019 | 02:11 PM
  #49
Wally's Avatar
Were doomed!
Originally Posted by PremierDetailer
Would it be safe to idle a mile to the boat ramp or am I going to need to tow this thing?
At this point i dont think you'll do any more damage to the piston or cyl walls then there is all-ready....if oil pressure is good and the motor will stay running and its not making any bad knocking noises then i say go for it to the launch ramp...
I once threw a piston and rod out the bottom of the engine cause the builder forgot to tighten one of the rod cap bolts....other then the fact all the oil was gone and it was shaking a little bit the motor still ran! i drove it home at idle for 3hrs to the launch ramp on the other engine then started up the hurt motor at the dock to load it on to the trailer! I was shocked
-Wally
Wally is offline
Old 07-09-2019 | 02:16 PM
  #50
F-2 Speedy's Avatar
that things making more noise than a 8V 92 detroit
