Oil filter attached to valve covers LEAK >
Old 07-10-2019 | 03:50 PM
  #71
Could do a compression and leak down check which would let U know where the engine health is, but I think it in serious need of a rebuild/replacement.
PA.WOODCHUCK is offline
Old 07-10-2019 | 04:13 PM
  #72
Full Force's Avatar
Gonna find a hole in piston I bet, probably broke valve or detonated, that blow by is all cylinder pressure in the video.
Full Force is offline
Old 07-10-2019 | 04:14 PM
  #73
Full Force's Avatar
I would find a 350 merc for 500 and go boating while you fix this one gonna be a full rebuld I bet.
Old 07-10-2019 | 04:20 PM
  #74
Originally Posted by underpsi68
Milwaukee makes a reasonably priced scope that fits thru spark plug hole. I cant remember the model number??
I have the Milwaukee and it definitely fits through the spark plug hole.
payuppsucker is offline
Old 07-10-2019 | 05:21 PM
  #75
Craney's Avatar
When you get that motor out make sure you put a bilge blower in.
Craney is offline
Old 07-10-2019 | 05:35 PM
  #76
Question... it seems like this engine is pretty high strung to get the power he enjoys. Would he be better off with a more mild set up and 177 huffer on top?
Baja Rooster is offline
Old 07-10-2019 | 11:44 PM
  #77
He'd be better off swapping to a mild 454/502.
Griff is offline
Old 07-11-2019 | 04:47 AM
  #78
Full Force's Avatar
needs some time and education first, he said he was not used to bigger power, start small and work your way up..
Old 07-11-2019 | 06:09 AM
  #79
motor looks to be nice . l am willing to buy it , if op wants to swap to ls bbc whatever
hotrodford is offline
Old 07-11-2019 | 10:57 AM
  #80
I agree. Whoever rigged it did a nice job, especially given the fact that it has a little age on it.
