Best option for Bravo One Sea Water pump ? >
Old 02-18-2020 | 10:51 AM
@flashgordon do you have a pic of your bracket? Part number of your pump? Thanks!
tbev is offline
Old 02-18-2020 | 10:53 AM
BUP
Originally Posted by Unlimited jd
Replace the impeller and plastic housing each season. It’s about $40 more than just a good impeller.
Bingo that has been a proven winner for over 30 years now. I use to be able to get the Bravo black plastic housing that had bigger openings from an aftermarketer. That housing was more solid plastic unit than Merc black plastic housing. It is no longer available. It pumped more water as well. it had about 12 % more water flow. Used the standard OEM bravo impeller as well.
BUP is offline
Old 02-18-2020 | 10:57 AM
I think its a little over $100 buck for the whole merc pump? Why bother I just replace the whole thing, was a spring thing when in Indiana just so I knew I didn't have to worry the rest of the season, down here IDK, every 100 hours. I burn way more in gas each day than two pumps.
I will say one weekend last year I changed mine 3 time!,,,,, but that was a brain fart weekend.
Wildman_grafix is offline
Old 02-18-2020 | 11:53 AM
Who's got the best price for the factory merc pump?
tbev is offline
Old 02-18-2020 | 12:27 PM
BUP
the OEM kit is 100 bucks and someone will be posting a link to the cheap knock offs at 42 bucks. I would not use those because the impeller is junk.
The OEM Mercruiser kit you should not be able to find under 95 bucks. To be honest for dealers selling these online is not even worth it because at 95 bucks there is not much made on just a pump kit unless the order is other parts being bought. .
BUP is offline
Old 02-18-2020 | 12:31 PM
Assuming your talking about the older style pump kit search 46-807151A14. Can find them even at Walmart for $95 and change on line, free ship (appears to be coming from Busters marine thru Walmart)
If your talking newer or entire pump assemble, need to specify
AllDodge is offline
Old 02-18-2020 | 12:52 PM
BUP
correct like I said the OEM should NOT be online for less than 95 bucks in which I am glad that most are following these OEM policies.
I have them as well and IMO I would buy from whomever on this site that supports it and helps others.
Why give busters and Walmart and amazon the biz - they are not up here supporting nor helping the site.
BUP is offline
Old 02-18-2020 | 12:53 PM
What's the difference between the newer and older, one or two piece units? I'm building a new system, I need the entire pump.
tbev is offline
Old 02-18-2020 | 04:50 PM
Here’s the good one
Amazon Amazon
Crude Intentions is offline
Old 02-18-2020 | 05:33 PM
Originally Posted by Crude Intentions
Here’s the good one
Thanks, how about the rest of the pump?
tbev is offline
