Best option for Bravo One Sea Water pump ? >
Old 03-14-2020 | 09:03 PM
  #51
Anyone running one of these? Impressions?
https://www.ebay.com/itm/SEA-WATER-P...EAAOSwo4pYD4p2
Tractionless is offline
Old 03-14-2020 | 10:41 PM
  #52
Originally Posted by Tractionless
I have just the SS housings affixed to the OE Merc pumps on '96 7.4LX MPI's. I've run the impellers for two seasons with zero end wear and only "wrinkling" on the insides of the impeller blades. Actually thinking about going 3 seasons on the impellers. I only buy the rebuild kits with the plates every other impeller change as I flip the plates to give a fresh wear surface to the impeller. I've seen no drop in water pressure doing this nor running the impellers for 2 seasons.
Thanks that seems like the best move to me, I'm going to buy a merc pump and then buy that stainless housing / kit next season.
tbev is offline
Old 03-15-2020 | 09:11 AM
  #53
I've been running a SS Hardin pump on my 525 for 10 years or so now. I used to replace the impeller every year but they always look like new so I changed to every other year. Last year my water pressure dropped and sometimes the pump would not prime itself and I had to get the boat moving forward to force water into the intake and then it would be ok the rest of the day but pressure was still lower. I rebuilt the pump twice and the second time I reversed the wear plates. Still had the same problem. Last week I rebuilt the pump with a hardin kit with new wear plates and hopefully problem will be resolved. Has anyone else experienced this? I did check everything else I could think of that could cause a drop in water pressure. My plastic pump did break at the hose connection and that's when I switched to the Hardin.
thirdchildhood is offline
Old 03-15-2020 | 09:19 AM
  #54
Bravoits maybe
AllDodge is offline
Old 03-15-2020 | 09:48 AM
  #55
See post #50
Old 03-15-2020 | 04:50 PM
  #56
OK, I'll see what happens when I can get on the water but the pump has worked well for many years. Probably something else going on.
Old 03-15-2020 | 09:04 PM
  #57
Who has the best deal on the factory pump w the plastic housing? I know most places are all pretty close on price, anyone have a sale coming up, free shipping, anything?
tbev is offline
Old 03-17-2020 | 10:38 AM
  #58
Looks great but the housing is usually not the issue, those damn impellers are
Pismo10 is offline
Old 03-24-2020 | 03:06 AM
  #59
I'm gonna cave in and get the new Hardin gen 7 plus, any vendors that sell it? Is there any reason I can't run a v belt pulley with it on my SBC?
tbev is offline
Old 04-22-2020 | 08:50 PM
  #60
No problem with impellers here. About to try 3 seasons outta my Merc impellers in Hardin SS housings. After 2 seasons there's only a wrinkle in each blade and water pressure is same as new. I NEVER run shallower than 2' below my resting draft; therefore, I do not see murky water. Fully raw water cooled with wet tips and no sea strainers.
I do have a pump housing leaking lube so I ordered the unit referenced in post #51. I guess I'll be the guinea pig as I'm not wanting to rebuild OE.
