Crank-mounted water pump? >
Old 10-04-2021 | 06:26 PM
Originally Posted by TomZ
That's nuts!
I'd imagine this is especially important on a Gen VI block where the water jacket to side of the block surface is thin. My 502s seeped at the head/block joint due to high water pressure. It'll no longer be an issue with closed cooling but it was a big problem when raw water cooled and at speed.
use cometic headgaskets and you won't have any weeping
sutphen 30 is offline
Old 10-04-2021 | 07:04 PM
TomZ's Avatar
I hear you. The problem started before I owned it and two top-end refreshes past.
question… Isn’t it the rule to not use Cometic gaskets unless the surface can be machined per their specs? I would think that would preclude their use during a top-end refresh. Not trying to derail my own thread, it what’s the consensus?
TomZ is offline
Old 10-07-2021 | 09:58 AM
TomZ's Avatar
Any thoughts on what to do about the removal of the Merc pump and serpentine belt routing? The way it works in stock form, the belt goes from the circ pump then down to the raw water pump then up to the alternator. Removing the raw water pump… can I just go to the alternator or should I get an idler? I thought about leaving the pump assembly (sans impeller) on the engine, but honestly, I'd like to sell them to recoup some of the cost.
TomZ is offline
Old 10-07-2021 | 11:22 AM
TomZ's Avatar
Looks like this is acceptable...
This is a 5.7L but the routing is basically spot-on for the 454/502 MPI accessory drive. They go straight across to the alternator and then back to the tensioner. The tensioner is much larger on this setup.
TomZ is offline
Old 10-07-2021 | 11:38 AM
F-2 Speedy's Avatar
I used the Felpro MLS when I added the Whipples, no machining done
F-2 Speedy is offline
Old 10-07-2021 | 08:56 PM
TomZ's Avatar
I got a pair of 3/8 billet spacer plates in from Speedway Motors today. They’re needed to make up some of the depth needed to keep the pump housing for hitting the pulley. I took everything up to Lowes to get some spacer/bushings. 3/8 inside, 1/2 outside. I’ll need to cut them down but they center the bolts perfectly. This should be easy to put together. I’ll get some pics as I’m putting it together along with part numbers used to put it all together.
TomZ is offline
Old 10-07-2021 | 09:41 PM
SB
Uh oh, he said “easy.”
SB is offline
Old 10-08-2021 | 07:40 AM
TomZ's Avatar
Famous last words!
TomZ is offline
Old 10-08-2021 | 07:55 AM
the only "easy" way to go boating is to give someone a $100 for gas and ride with them. at the end of the day you go home while they deal with the boat and you rode around on the same boat they are spending all their time fixing. but seriously, I work on several boats that have a crank driven pump and they are so much easier to deal with in cramped compartments. as for water flow, never seen an issue, heck, my jet boat only had a 3/4 hose from the pump cooling the engine and as hard as it got run the temp never climbed with a crossover and no thermostat.
compedgemarine is offline
Old 10-09-2021 | 01:12 PM
TomZ's Avatar
So much for easy… but not the way you’d think.
I landed bad when I jumped off the back of the boat last weekend. I knew I did something wrong because I felt the front of my left foot stretch much more than it should. Started out limping Saturday night and now it’s all jacked up… I can barely walk on it. I went out to dinner with my girl last night and couldn’t even get a flip-flip on it let alone a shoe. Guess I’ll be off of it for a while. Shoot.
TomZ is offline
