Tunell raaammm!!!! >
Tunell raaammm!!!!
Tunell raaammm!!!!
Old 12-26-2021 | 09:12 PM
  #141
Rookie's Avatar
Originally Posted by SB
Smitty, i came across this pic year or two ago. I’d be damned I can’t find anything on this intake anywhere. It has to be somewhere.
I believe that is an 8.1L/496 intake manifold.
Rookie is offline
Old 12-26-2021 | 09:32 PM
  #142
bencini231's Avatar
That looks like the 8.1L/496 intake that Tyler Crockett had for a little while. There was a Advantage boat over at LOTO for sale with one just like that a few years ago.
bencini231 is offline
Old 12-27-2021 | 10:59 AM
  #143
Originally Posted by ICDEDPPL
Well well , that seems like if it truly works to help with detonation like a no brainer.
You may have seen this however thought I’d post anyway. Something not discussed much.
https://www.yellowbullet.com/threads...or-na.2657091/
http://www.rockettbrand.com/download...low%20Burn.pdf
getrdunn is offline
Old 12-27-2021 | 11:21 AM
  #144
bob
Charter Member #40
Tech-Fast%20Burn%20Or%20Slow%20Burn.pdf
Looks like this is angle cutting the heads? In effect reducing chamber volume? That has been going on for a couple decades I am thinking. Big Chief chambers were like 75-80 cc's and didn't like timing much over 30 deg?
bob is offline
Old 12-27-2021 | 11:51 AM
  #145
For sure - just doesn’t get brought up much. Not that I’ve seen here anyway.
getrdunn is offline
Old 12-27-2021 | 01:08 PM
  #146
[QUOTE=bob;4816312]Looks like this is angle cutting the heads? In effect reducing chamber volume? That has been going on for a couple decades I am thinking. Big Chief chambers were like 75-80 cc's and didn't like timing much over 30 deg?[/QUOTe
when they angle cut the quench it's done on a 5 axis because it's only the quench in the combustion chamber that gets cut. Not the whole deck.
KWright is offline
Old 12-27-2021 | 01:11 PM
  #147
So in effect it actually increases the volume of the chamber so it will lower the compression.
KWright is offline
Old 12-27-2021 | 01:15 PM
  #148
As KWright said. They're not reducing chamber volume, actually would increase it slightly.
They sort of "Hemi" it so to speak. Angle mill just the flat areas of the chamber, towards the center.
cheech is offline
Old 12-27-2021 | 01:22 PM
  #149
bob
Charter Member #40
I used to have a guy put my heads on a flow bench and put a piece of yarn in the air path and watch to see where the circular pattern was in the chamber and then re-configure squish area to get center of flow to be in center of chamber. Did each chamber. Not really sure if it was all that important but it sounded good at the time.
bob is offline
Old 12-27-2021 | 01:27 PM
  #150
FWIW, Arizona Speed and Marine from what I can come up with. Old thread regarding one.
Arizona Speed & Marine 625 HP engine
And the most recent thread that I remember that picture from. (Which was a pure sh it show)
idle timing with Holley HP efi
Anyhow, back to Tunnel Rams.
cheech is offline
