Tunell raaammm!!!! >
Tunell raaammm!!!!
Tunell raaammm!!!!
Old 11-29-2021 | 05:36 PM
  #61
Question: Old intakes had the rear water passages tapped for the steam pockets I believe is the reason. Is that still a thing or an old wives tail?
Should I tap the TR water passages ?
ICDEDPPL is offline
Old 11-29-2021 | 05:37 PM
  #62
Originally Posted by speicher lane
After grinding to prevent leaking @ joint as per boat freaks thread
Did that work ?
is this possibly a new design?
https://www.cpperformance.com/p-8014...ve-covers.aspx
ICDEDPPL is offline
Old 11-29-2021 | 05:54 PM
  #63
Rookie's Avatar
I took out 3-4 exhaust valves on my old Merlin heads. 30 seconds on plane each time. Vowed to always have them flow water. Dyno'd new EFI setups (Dart heads) and forgot to drill new EFI intakes. Didn't have a problem, but probably going to do it over the winter.
Rookie is offline
Old 11-29-2021 | 06:57 PM
  #64
I figured, better safe than sorry.
Thanx
btw here some cheap 2 piece valve covers
https://www.summitracing.com/parts/rnm-r400
ICDEDPPL is offline
Old 11-30-2021 | 04:45 AM
  #65
Thanx
Looks like a time capsule OR a coffin for Gates, Zuckerberg, soros, etc!!!! 😂. Nahhhh just a coffin.
getrdunn is offline
Old 11-30-2021 | 06:39 AM
  #66
articfriends's Avatar
Originally Posted by getrdunn
On way!!! 👍
When they come, post up measurement of port opening CSA at head and at plenum, the numbers listed on summit are clearly incorrect at 2.36 x 1.68 or you'd be grinding for weeks
articfriends is offline
Old 11-30-2021 | 08:55 AM
  #67
Those 2 piece covers are the original Keith Eickert design that Hardin/CP now own the patent to and sell. If you want the new redesigned covers that KE sells you have to go directly to their web site and order directly. KE Auto and Marine. The easiest way to tell them apart is the two bolts that hold the cover on are outside of the gasket sealing surface. I have not had a chance to run my new ones yet, but I see no reason why they would not work well just looking at the design.
jdpoof is offline
Old 11-30-2021 | 09:53 AM
  #68
SB
Thanks for info.
Here is link
Two Piece Valve Cover - KE Automarine by Keith Eickert
SB is offline
Old 11-30-2021 | 11:14 AM
  #69
bob
Charter Member #40
Originally Posted by SB
Keith has them in stock. Keith claims they have not had the leak issues with the new design. You can reach him at 386-283-0885.
bob is offline
Old 11-30-2021 | 11:43 AM
  #70
How much. 2 bolts really nice! Personally I don’t really care for the looks rather the purpose.
getrdunn is offline
