BOOSTane ??
Old 02-26-2022 | 04:47 PM
Default BOOSTane ??
Anybody using BOOSTane or other brand octane boost with good luck ?? With the crap fuel and even more nowadays gunna use a additive every fill up
thanks
PROP STAR is offline
Old 02-26-2022 | 05:32 PM
I have Friends that use it and swear by it, all in Super Charged Boats, I have not tried it yet but might this season in the Pro -Charged boat Max boost is 9 LBS
The 1471 boat uses Race fuel.
Hope that helps you a little,
I would like to see what others say as well, as I don't have any first hand experience with it.
abones is offline
Old 02-26-2022 | 07:15 PM
Rookie's Avatar
Many thread in the General Discussion on Boostane.
Boost Octane...local marinas have 87
Boostane buy one get one free code
Octane Booster?
Rookie is offline
Old 02-26-2022 | 07:38 PM
I have ran it in the Cuda (I use the marine formula) and have had good luck out of it but I have not raced with it yet. Normal cruising and some hits on the street I could not tell much difference between the boostane/93 mix and VP C14 btw engine is a high compression stroker small block
Thanks Chris
moparcrazzzy is offline
Old 03-05-2022 | 09:39 PM
KAAMA's Avatar
Boostane is a true real deal octane booster that won the 2014 SEMA Award (do a google search)---it was actually invented by Dave Wesseldyk of WESCO Marine in Jenison, Michigan---a small town suburb area just southwest of Grand Rapids, Michigan. He invented Boostane with offshore boaters in mind to help with the poor quality of gas you might get at a marina or gas station---it works in other gas engines too, even snowmobiles. Kieth Eickert even endorses Boostane on his website if that means anything.
Dave was a World Class throttle-man in the offshore racing circuit since the 1990's designs and builds some very sophisticated marine hi-perf engines.
KAAMA is offline
Old 03-06-2022 | 06:26 AM
When I was playing with a tune on my RX-7 I was needing better than 93 octane for the map, so went and researched most of the octane boosters (but NOT Boostane) and was amused to find that, once you got past all the b.s., the 'real' increase in octane amounted to ONE TENTH of a point. Evidently Boostane is better than this, according to the reviews?
Baja 252 Islander
bajaman is offline
Old 03-06-2022 | 07:39 AM
Kept a couple of cases on hand in the boat for those times in need of marina gas. Worked well and did the job. 525 sc’s and 675 sc’s.
getrdunn is offline
Old 03-06-2022 | 05:02 PM
That is correct, the junk stuff raises octane in the tenths of points. Boostane is the real deal. I used it on lakes with only 87 available and added it to get around 95+ as needed. I run wide band full time and it did not affect the sensor either.
Trash is offline
Old 03-06-2022 | 10:53 PM
Originally Posted by KAAMA
it was actually invented by Dave Wesseldyk of WESCO Marine in Jenison, Michigan---a small town suburb area just southwest of Grand Rapids, Michigan. He invented Boostane with offshore boaters in mind to help with the poor quality of gas you might get at a marina or gas station-.
Oh so now Dave Whistledick is a chemist ??? lol
omg some of you michigan guys really think that guy is the second coming.
ICDEDPPL is offline
Old 03-08-2022 | 05:59 AM
Did you have a bad experience? Ive heard mostly great things. Chemist...lol
kreed is offline
