496HO Down on power
#131
So scanning a ill running engine is a waist of time and Mr Good-wrench suspects head gaskets after you have done a compression test that looks ok, Im not sure if Id let Kankles touch it
#132
That's why I asked. I'm not too keen on ANYONE digging into an engine that doesn't need dug into. I'm not one to go hunting for zebras.
I'm still thinking this is a relatively simple fix that has so far eluded diagnosis. And I'm going to keep exploring possibilities that rule out hypotheses until I run out of them.
Riddle me this..... Which "goes" first? Compression numbers or leakdown?
Thanks. Brad.
(937)545-8991
#133
Did we use the spark tester yet ? No ? Why are we still guessing/wondering about things ?
F2 - i luv you man
:wink
btw: in the last two hrs i just got a seadoo boat with merc 240efi only tunning with 3 cyl’s, too all 6. Getting the fuel psi from over 50 to proper 35 took a bit longer though. 2 weeks+ for a freaking fuel module gasket. Uggghhh
Just putting a timeline out there.
F2 - i luv you man
:winkbtw: in the last two hrs i just got a seadoo boat with merc 240efi only tunning with 3 cyl’s, too all 6. Getting the fuel psi from over 50 to proper 35 took a bit longer though. 2 weeks+ for a freaking fuel module gasket. Uggghhh
#134
F2 - i luv you man
:wink
F2 - i luv you man
Used the spark tester last night, but only at an idle. All eight were showing spark at idle. Not really sure how I’d use it under load. Don’t know if I want to run down the lake with the sundeck up.
Thanks. Brad.
(937)545-8991
#137
Guys,
Plugs out. Same as last findings. #4 and #7 showing no signs of combustion. Squeaky clean. MAYBE a hint of a smell of gas on these two. Kind of hard to be sure.
I’ve also noticed a consistent appearance of oil around the threads of #7 each time I’ve taken it out. Not a lot. And not inside the cylinder. Outside. Might have a leak. 🤨
Since #5 was of interest previously, I took some closeups of it, as well. I’m not sure what was going on with it last time, but it looks pretty much identical to the others this time around, excepting #4 and #7, of course.
Thoughts?
Next, I plan on swapping the injectors. Ill swap them the same I did the coil packs; 4-6 and 7-5. I’ll take pictures of them as I do so. I’ll also figure out a way of getting some video of the spark tester in use, under load, on the water.
Repeat…. Anybody have any actual dealings with Kunkel’s?
My hips and shoulders are going to mount a protest before long….. 🙄
Thanks. Brad.
(937)545-8991
Thoughts?
Thanks. Brad.
(937)545-8991
#139
DrFeelgood,
I did a compression test. Results are posted above. Those numbers look good, although the starboard side was stronger than the port side. I don't know if that means anything or not. I have no means to do a leakdown test and I can't find anybody willing, able and ready to do one until the middle of September. I am scheduled to take the boat to Kunkle's the third weekend in September, and I'm sure that's one of the first things they'll do. In the meantime, I'm pursuing other possibilities.
Thanks. Brad.
(937)545-8991
Thanks. Brad.
(937)545-8991
#140
If you have a home air compress this should work
Harbor Freight Tools – Quality Tools at Discount Prices Since 1977
