496HO Down on power
#231
Yeah. Kinda not the same thing. Gotta love that, though.
Thanks. Brad.
(947)545-8991
#232
Guys,
So…. Now that we’re back up to HP, I’m looking at props. I’m currently running a Bravo1 26P, and it’s not nearly enough prop. The boat leaps on plane and is just shy of the rev limiter (5250) at about 75-80% throttle. So what should I be looking for. I know props are typically a trial and error thing, but there’s a wealth of knowledge here to tap into.
I’m working on a couple of 28P options. But I’m also thinking it may not be enough. What do we know about the BravoFS props. They are available in 1” increments, making a 29P a relatively easy option. Would a 30P be too much?
Thanks. Brad.
(937)545-8991
Thanks. Brad.
(937)545-8991
#234
I kinda feel like I’ve already rung it out at 5100RPM. Stock WOT is 4600-5000. I know it’s got the forged crank and rods, as I ran the numbers through Merc, but don’t want to throw a rod finding the “limits”. I think we’re already at a point we know we need more prop.
Thanks. Brad.
(937)545-8991
#235
Guys,
Here we go. Way better video quality and starting from an idle.
What you don’t see here is that the throttle is at about 75-80% at its highest.
Thanks. Brad.
(937)545-8991
Thanks. Brad.
(937)545-8991
#237
#238
Just because the throttle lever is at 75-80% does not mean its not at 98%. Most boat's throttles are not all the way forward at actual WOT. Push it forward and see how much farther it goes and if it hits the limiter. If it does hit the limiter, then go to 28" Bravo. 2" of pitch = about 400rpms.
......... Id run it all the way out with what you have and see where it goes before spending any money
