496HO Down on power >
496HO Down on power
496HO Down on power
Old 07-31-2022 | 01:20 PM
  #81
SB
Someone tell me why someone should run more than .040 gap on anything ? I’m all ears.
SB is offline
Old 07-31-2022 | 02:00 PM
  #82
Have my street car gapped at 025. No difference how it runs from 025 to 055. Put down almost 1100rwhp. Less gap for the win.
underpsi68 is offline
Old 07-31-2022 | 05:16 PM
  #83
Guys,
Pretty sure I managed to save the tapped hole in the exhaust riser base. Not much scarier than turning a tap, with an adjustable wrench, in close quarters, where I have to swing the wrench over obstacles while I turn it. Gotta love form taps, though. I didn't over tighten the bolt, but I don't think it's under a lot of stress. It's just an anchor point for the shifter bellcrank assembly, and there are two more anchor points. I'll keep an eye on it for a while.
Apparently, these now-fangled coil packs cannot be tested with a multimeter. Something about internal switching and such. Oh, well. We'll just do it the old-fashioned way.
Coil packs are swapped. Waiting for new plug wires from Mosetti and I'll swap the new plugs in while I'm at it, then it's time to get the boat on the water and see if the wet plugs follow the "bad" coils.
Shout out to Smitty, for enduring all my questions over text. Especially on a Sunday.
Thanks. Brad.
(937)545-8991
Brad Christy is offline
Old 08-01-2022 | 07:47 AM
  #84
Guys,
What is this widget? And should there be something connected to that nipple pointing to the left?
Thanks. Brad.
(937)545-8991
Old 08-01-2022 | 08:00 AM
  #85
SB
Good question. The aluminum thing under bolt is for sourcing intake vacuum. The sensor on left attached to it by vac line is the map sensor. The round item to left of that is a one way valve. But question i share with you is why isn’t this hooked up to something ? Should it be hooked to fmu or is there a vac line to it already ? Or, shoukd vac line end at map sensor ? I’d talk to ati/procharger on this. Looks like their deal as the oe engine’s map sensor is typically where that aluminum piece is.
SB is offline
Old 08-01-2022 | 11:39 AM
  #86
Guys,
Are these two coil packs interchangeable?
Amazon Amazon
https://www.amazon.com/ACDelco-D581-Original-Equipment-Ignition/dp/B000BYGD60?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&psc=1&smid=ATVPDKIKX0DER https://www.amazon.com/ACDelco-D581-Original-Equipment-Ignition/dp/B000BYGD60?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&psc=1&smid=ATVPDKIKX0DER
The first one seems more readily available and is listed as a "newer" model. In the event I find I need to replace mine I want to have a plan in place.
Thanks. Brad.
(937)545-8991
Old 08-01-2022 | 12:01 PM
  #87
SB
Appears to be same.
You can also go to acdelco.com. Go yo parts look up and interchange #.
SB is offline
Old 08-01-2022 | 12:04 PM
  #88
Originally Posted by SB
Appears to be same.
SB,
And cheaper than Amazon, too. 😎
Thanks. Brad.
(937)545-8991
Old 08-01-2022 | 12:21 PM
  #89
SB
SB,
Thanks. Brad.
(937)545-8991
RockAuto charges shipping, so need to fully compare total amts. And shipping time, if it matters.
SB is offline
Old 08-01-2022 | 12:33 PM
  #90
SB,
Thanks. Brad.
(937)545-8991
I may be wrong. But IMO I doubt you'll get any counterfeit parts from Rockauto VS the probability from various Amazon sellers.
I do see in the links they say ACDelco store.
So hard to say.
My gut always uses Rockauto.
cheech is offline
