496 mag ho suspicious performance >
Old 06-07-2023 | 08:38 AM
TomZ's Avatar
If you're going to keep it for a while, buy the scan tool. Rinda Technologies - you'll be able to troubleshoot it easily.
TomZ is offline
Old 06-07-2023 | 09:01 AM
Years ago my 496 Ho did the same thing,,,Remove the air intake screen just above the serpantine belt, the belt ,,dust,, sucks directly into the air intake, no mechanic could find the problem, after 4 weeks of derating engine, I removed the intake screen and it was full of belt dust, starving the engine for air,,after cleaning the intake screen it was perfect again,,just sayin check the small stuff.
253 is offline
Old 06-07-2023 | 09:46 AM
While you are doing that...check the IAC muffler too. Those can get gunked up or worse sucked into the intake.
techman is offline
Old 06-07-2023 | 10:03 AM
F-2 Speedy's Avatar
Id guess water pressure alarm......sea pump might need a overhaul.
F-2 Speedy is online now
Old 06-07-2023 | 12:14 PM
Filter was cleaned two weeks ago … brand new stainless hardin marine pump was also installed two weeks ago … brand new plug new oils … lot of things here are eliminated … idle is perfect engine starts really well …
Outlawmarc is offline
Old 06-07-2023 | 12:38 PM
BBYSTWY's Avatar
Is it bouncing off the rev limiter? I haven't messed with one in awhile but I think the limiter will sound an alarm and pull RPM after so many times hitting it I think...could be wrong tho like I said been awhile lol
BBYSTWY is offline
Old 06-07-2023 | 12:40 PM
All rpm parameters seems to be on point … no bouncing and never hit rev limiter… just a 2 beep alarm … then sound like a loss of power afterward … im scanning it this weekend will keep you guys posted on this one .
Old 06-07-2023 | 12:42 PM
BBYSTWY's Avatar
I'm still thinking water pump actually....I know you said it's new but I think those have a flow and temp sensor for the water and you may not be getting the flow it wants or bad sensor or clogged sensor/line....keep us posted good luck!
BBYSTWY is offline
Old 06-07-2023 | 12:50 PM
The two beep alarm is the equivalent of a car's "check engine" light. Your guessing until you scan it. Hopefully it doesn't become a "change engine" light.
techman is offline
Youre right on this one and this is what i assume also … pump is doing really fine mechanically but maybe a pressure/temp sensor failure here …
