BBC intake flow
#31
I understand the point, my heads are not peanuts, they are oval 049, port matching with a gasket,
I was thinking of a long port design like the tunnel ram but with less height, the MR 500/525 intake seems to have longer ports than any other I've seen, it has a CSA that appears to be good (I don't know its measurements) and a large plenum.
From my limited knowledge, I don't see the downside to using it in a 454 NA; teachme please.
Another point that I find beneficial is how the injectors are located.
Beyond that, it boils off and chokes off the flow to a narrow area.
049 heads have big potential. They have an easy NA 550hp in them, but that depends on where you make your peak RPM.
Oval ports with blowers would work really well. As long as you get close to the requires Cross Sectional Area of the ports etc. The CSA needs to be tuned to the task and the port/valve etc. Often making CSA a little smaller CSA is what is required to get the port air velocity up.
MR 525 intakes can get away with a bit of the cornering with dry, unfueled air. If the int man ports are enlarged at the elbows, it slows down the air to make the turn, but it also losses energy, making the pumping losses higher. They'll work for you on a 454, but the length of port will play a factor. Once they get too long, a larger port diameter will not help. The air velocity will tank.
Porting to gaskets is a paradigm. Gasket makers know zero about the best port size for your engine. There's just bigger and smaller ones. Nothing wrong with a 40 thou gap in the int to head port transition. If anything, it it would help as a liquid fuel atomization zone.
The intake to head transition just wants to have no steps protruding on the head side. Smaller int man ports into larger heads are not as much of an issue.
Porting to a gasket can make the port larger and needlessly bulge it out...slowing airflow, losing velocity.
To properly port match, place the intake on the heads with the gaskets you're using. Put a camera down the intake port and see how it lines up. For that matter, just because you port match to the gasket, doesn't mean that the ports will line up vertically when installed. All depends on gasket thckness.
Did I miss where you stated HP goals? I've just seen 5800-6000 rpm.
049 heads need to be properly ported before you increase the int valve size, or it will choke off hard at low lift. The air draw is very soft. It's like drawing the air in with a slinky spring, vs a valve spring. The following air just doesn't have the same velocity and energy.
Int valve throat (no more than 90% dia of int valve) should be the smallest CSA of the intake track.
A 2.06" int valve has an area of 3.33"sq. 90% is 3.00" CSA.
The curtain of the int valve lift at 0.500", is about 3.25" Sq CSA. So if you're running low lift cams that don't exceed 0.500" lift., the valve curtain area is the smallest CSA.
#32
#34
Theres (4) left in world to be purchased : https://ebay.us/m/lxKTMx , IDK why they discontinued that bell mouth
I just drew them up in 5" & 6" air filter sizes and printed a couple rubber ones up.
What filter have you been using with these throttle bodies?
#35
#36
yes, I have several as Ive seen a 35+ hp gain using them on a 102/ 105 mm tb and still have 2 new proflow rect ports and modded TBs for my upcoming personal twin 548 project on my own boat. I AM going to buy one of the holley tunnel ram, front tb intakes though for my dyno test on intakes, its still my be a little big even for my 548 though, Smitty
#37
Might you be willing/able to send me one to measure up?
Thanks. Brad.
#38
Have a look at Pipemax software.
Worth every penny of the $150. It would go through what you would need to for your engine for intake and exhaust, and give all the harmonic tuning lengths etc.
As Arcticfriends mentioned, the Mercury Racing chokes off at 5500 area. But it's likely restricting airflow from optimum potential before it really chokes off.
Originally Posted by sb
Found a 502 with max power 5600rpm I had run into pipemax:
@ 5800 RPM
- Induction System Tuned Lengths = (Cylinder Head Port + Manifold Runner )
1st Harmonic= 35.485' (usually this Length is never used)
2nd Harmonic= 20.140' (some Sprint Engines and Factory OEM's w/Injectors)
3rd Harmonic= 14.061' (ProStock or Comp SheetMetal Intake)
4th Harmonic= 11.067' (Single-plane Intakes , less Torque)
5th Harmonic= 8.979' (Torque is reduced, even though Tuned Length)
6th Harmonic= 7.554' (Torque is reduced, even though Tuned Length)
7th Harmonic= 6.520' (Torque is greatly reduced, even though Tuned Length)
8th Harmonic= 5.734' (Torque is greatly reduced, even though Tuned Length)
Note> 2nd and 3rd Harmonics typically create the most Peak Torque
4th Harmonic is used to package Induction System underneath Hood
Plenum Runner Minimum Recommended Entry Area = 2.865 to 3.223 Sq.Inch
Plenum Runner Average Recommended Entry Area = 3.294 Sq.Inch
Plenum Runner Maximum Recommended Entry Area = 3.365to 3.981 Sq.Inch
Minimum Plenum Volume CC = 1113.7 [typically for Single-Plane Intakes]
Minimum Plenum Volume CID= 68.0 [typically forSingle-Plane Intakes]
Maximum Plenum Volume CC = 8229.2 [typically for Tunnel Ram Intakes]
Maximum Plenum Volume CID= 502.2 [typically forTunnel Ram Intakes]
SB is offline Report Post
#39
#40
