Qusestion on 350MPI >
Qusestion on 350MPI
Qusestion on 350MPI
Old 12-26-2002 | 10:41 PM
Unhappy Qusestion on 350MPI
Could any tell me if the 350MPI motors have good parts? Is the crank steel or cast,and if they have forged or cast pistons? thanks. Happy Holiday
nitro/max is offline
Old 12-27-2002 | 12:23 AM
SeaRay Jim's Avatar
Only thing different about the 350 MAG over the other 5.7's is fuel delivery. Everything else internal is the same.
From what I've heard, they are good for up to the 450 HP range.
SeaRay Jim is offline
Old 12-27-2002 | 06:48 AM
To the best of my knowledge, Merc has not changed their thinking on the 350Mag since its introduction in late '86 early '87.
All of the Mag engines still receive forged cranks and pistons (all the SBC rods were forged). This is based on the 4-bolt main block. The lesser models 5.7 and 5.0 get the same components that were used in their predecessor, the 260, which is cast crank and pistons, 2-bolt mains.
Unless you're getting very radical, the stock cast crank and pistons are more than up to the task of performance upgrades, other than supercharging.
jafo is offline
Old 12-27-2002 | 11:08 PM
Thanks for the replys!
Old 12-28-2002 | 11:25 PM
All Merc 5.7's(including the 350 Magnum) use a 2 bolt block, cast crank and cast pistons. The Vortec engines use powdered metal connecting rods, which are decent and better hypereutectic pistons.
bobl is offline
Old 12-28-2002 | 11:46 PM
ASK YOUR CHEVY DEALER,WITH THE ENGINE NUMBERS THE CAN TELL YOU.MERC GETS THE MOTORS FROM GM
JJONES is offline
Old 12-29-2002 | 10:33 AM
If you want to prove to yourself what parts are different, go to mercrusierparts.com and look up the various engines and cross reference the part numbers between the 5.7L and 350 Magnum. You'll see they are all the same.
bobl is offline
scarab-nick
7
11-24-2007 06:06 AM
NormRinker
07-31-2007 10:55 AM
Dono
Powerplay
6
03-15-2007 04:41 PM
berns29scarab
11-08-2004 07:05 AM
mikev
8
09-18-2003 03:21 PM
