Mark IV crank in Gen V block? Possible?? >
Old 01-13-2003 | 06:36 PM
Elite Marine's Avatar
Default GEN VI
Go with a Gen VI over Gen V. Email me, I know of several available, new and used.
Kirk
Elite Marine is offline
Old 01-13-2003 | 06:37 PM
Remeber, you now have to go to an electric fuel pump....
Old 01-13-2003 | 10:07 PM
blown formula's Avatar
I would like a lo of things... including Gen VI 502's !!!
The reason I am looking for a Gen V is I need twins and I now have one Mark IV & one Gen V. So, by choice I am trying to match to the Gen V and buy only one block not two!! I will still have a Mark IV left over after the conversion. The electric fuel pumps were already on my "need" list.
Now, if those Gen VI's are really reasonable,,,,let me know!! I would LOVE to have them!
blown formula is offline
Old 01-14-2003 | 06:46 PM
Does anyone know the difference between the gen v and the gen Vl?
572ci is offline
Old 01-15-2003 | 06:55 PM
blown1500
The main difference to us boaters is the VI has a fuel pump mount, the V does not. You will not notice any difference between the V and VI if you run one of each except the fuel pump mount. There are other differences for land-lubbers. I would try to get aftermarket heads. Merlins are cheap and great. The CI GM piece is no match for Merlins or almost any other aftermarket piece. If you find some cheap and in good condition and are on a budget, they will work.
Old 01-16-2003 | 08:01 PM
Mark IV heads will work on a gen 6 block but not on a gen 5 production block due to the changes in the cooling holes. Gen 5 heads will work on a gen 6 block too. Mark IV heads will work on a gen 5 bowtie block though. as previously stated, no mechanical fuel pump pad on gen 5 but it's back for gen 6. Mark IV is a two part rear main, 5 & 6 are one. main cap bolts on Mark IV is different length than Gen 5. Mark IV valvetrain is adjustable, gen 5 isn't but can be made adjustable. oil systems are different as well.
excaleagle42 is offline
Old 01-22-2003 | 10:01 PM
Ok, so does this mean:
A MK IV block will work with a MK IV crank & Gen V heads & intake, and a MK IV pan? will have adjustible valve train.
A Gen V block, MK IV crank w/adapter, Gen V pan, GEN V/VI heads
and valve train is not adjustible.
If the MK IV/Gen V head combo doesn't create problems like push rod lengths, then.....
Maybe I would be better off trading a Gen V block, crank & pan for a MK IV block, crank & pan??? Any takers???
Old 01-23-2003 | 07:05 AM
blown1500
Blown Formula,
You can use the V and VI heads on the IV block, the intakes interchange. Just ask your machine shop about the differences-more than I want to type, but not too bad.
Adjustable valve train on V and VI heads is no problem for any good machine shop and the pushrods, etc. are the same length, etc. Parts for this are the same as the parts for IV or Mercruiser 500hp or 502EFI. pm or call if you want more.
Old 06-23-2023 | 06:31 AM
Default Can you tell me where you got the ALUM stuff from I’ve got a Gen 6 with 2 piece
Originally Posted by Turbojack
This setup is what I have. My engine builder ordered it when he assembled short block. It is 2 pieces of alum. that go where the rear main seal is. New block wants a 1 piece rear seal where crank is for 2 piece seal. Have had for 3 years now & no oil leak thru rear main seal. If you need I can call & see where he got it.
need help
goody12347 is offline
Old 06-23-2023 | 09:31 AM
it looks like Jeg's has them in stock
snapmorgan is offline
fastlane40
12
12-19-2005 12:04 PM
DonMan
2
04-03-2004 11:51 PM
klmken
2
08-01-2003 09:25 PM
Scarab28
0
05-06-2003 08:48 PM
