Hey Shooter, care to explain this . . . >
Old 01-21-2003 | 07:03 PM
Elite Marine's Avatar
Default Hey Shooter, care to explain this . . .
The following is the rear main bearing from the Pantera. Why don't you and "those in the know, that know the real deal" explain how I caused this failure:
Elite Marine is offline
Old 01-21-2003 | 07:04 PM
The real deal is either the crank was out of tolerance:
Old 01-21-2003 | 07:05 PM
Or the thrust was never verified
Old 01-21-2003 | 07:09 PM
I don't belive the seal caused the leak, just contributed to the problem. The engine ran perfect up to the minute I pulled it, no alarms or anything. Please don't make assumptions about me or the situation. Something was wrong, unfortunate, but wrong.
Old 01-21-2003 | 07:57 PM
Shooter's Avatar
Charter Member #300
Sorry man,
Severe over-temping will cause a host of issues.
Not interested in sparring, you suggested I mind my own business. I offered a friendly "let's move on" suggestion. I can give and take advice.
Take care and enjoy the boat.
Shooter is offline
Old 01-21-2003 | 08:31 PM
JimV's Avatar
How much time was on the bearings? What brand crankshaft?
JimV is offline
Old 01-21-2003 | 08:41 PM
10 -14 hours, Eagle Crankshaft
Old 01-21-2003 | 08:52 PM
uh-oh, what I miss?
Pure Energy is offline
Old 01-21-2003 | 08:55 PM
If 130 degrees prior to shutdown is severe, then you're right Shooter. The loss of water pump occured at the ramp in a channel, I noticed it immediately due to the dry exhaust, idled the boat straight to the mechanic at the end of the channel. Never had the engine over idle. This was the very first launching of the boat after bringing it back from NJ.
Had the boat been at speed or any sort of load I could understand an over temp condition causing the bearing failure, but the boat idled in the no wake zone only. Hence my original concern about the rebuild. If it were a severe heat issue, there would be other damaged components, bearings, etc...which there are not.
Does any of this make sense or sound logical now that you are truly "in the know"? I'm not trying to be an a------, but I did nothing to cause this problem and resent your assertion that I did.
Old 01-22-2003 | 07:19 AM
Payton's Avatar
Charter Member #927
Did you have an oil temp guage?
My old 486" Twin turbo/700hp, did get hot after a 1/2 mile idle with bad impeller. My ehaust is at the water level so I never cought the dry exhaust.
Payton is offline
kennyo
Baja
10
06-30-2022 08:42 PM
stecz20
07-11-2008 09:47 AM
Shooter
Baja
9
09-08-2002 07:08 PM
Riverrunner
Baja
16
03-13-2002 11:27 PM
