Circulating pump question >
Old 03-15-2003 | 09:10 AM
Iggy's Avatar
Question Circulating pump question
Picked up a new pump and was wondering what, if anything, I should use on the gaskets.
If I was installing it on a car I would use Permatex #2.
Since this is first I've done on a marine engine I don't know if thats really needed.
What do you guys use or think?
Iggy is offline
Old 03-15-2003 | 10:05 AM
paradigm shift's Avatar
#2 will work fine. New gaskets.
paradigm shift is offline
Old 03-15-2003 | 10:09 AM
Dennis Moore
Default Sounds good to me.
After you install it with Permatex #2 (also coat the bolts) run a continuity test between the water pump and the battery ground to make sure the pump is grounded otherwise it will corrode very fast. If there is no continuity, you should make a ground strap from 16 gauge wire, (stainless wire is the best).
Dennis Moore
Old 03-15-2003 | 10:23 AM
Iggy's Avatar
Thanks guys.
Permatex #2 it is.
Dennis, I never thought about checking for continuity. Thanks.
Iggy is offline
Ken N
3
09-24-2008 06:37 PM
sleeper_dave
7
03-28-2006 01:20 PM
JasonSmith
01-26-2006 12:41 PM
Curby
1
07-23-2002 11:27 PM
CAP071
18
04-30-2002 12:21 PM
