How fast will it go?
#61
i have a 1988 240sport with a 540dart 622hp n/a last sumer 136drive 23mirage prop at 5600 runnig low 80mph. it runs 80 all the time ! now this year i put more power going friday to test . i no a guy that does 98mph in a 24 outlaw . . the baja force hull is not the same hull . there is one thing when going over 60 mph you shuold have the rigth steering setup and long trim tab and a safety cut off switch hook to you . and drive that boat very carefull !!!
#62
#64
Thats a stout number for NA 454s at 5100rpm. You sure the dyno didnt have an overly optimistic correction factor ? My buddy had a 31 bullet with 600hp 509's, turned 26p bravo 1 props to 5400-5500
#65
6yr old thread.
He wrote this page before this:
I have a 572ci (through prop exhaust - because of restricted law...!) with a good 600hp in a Baja 235 Force (year 90) the prop is a 4-blades 26 with max. 4400RPM it run 64 mph last season. I know 4400 RPM is too low... So, I just have got a new 22 Merc Bravo1 4-blades prop. What should be the approx. result?
#66
That would be a good comp in a way in regards to my 28' challenger. 454's on roids deal and made 480hp. Turned 25p 3 blade mirage 5,600-5,700. Bravo one 1.5's. Prop's were tuned up a little with an edge on them but ran 78 plus. Weight was undoubtedly less than 31 bullet but not lite.
