which procharger??? >
which procharger???
which procharger???
Old 04-21-2003 | 03:14 PM
ROUGH WATER's Avatar
Default which procharger???
what would the ideal procharger be for a pair of 454s 330 hps with carbs? I know its not a good choice for the 330s due to weak lower but what model would be right? thanks
ROUGH WATER is offline
Old 04-21-2003 | 04:43 PM
bobby daniels
250 B&M 5 psi boost
or whipple ,,,but cast pistons ,,oh no
Old 04-21-2003 | 04:57 PM
ProChargers great ,M1 3.5-5 PSI,THRU-TRANSOM EXH. 7-9 PSI . You can make between 435-525 Crank HP.If you need more info ,such as where to buy or price.E-mail me
Dixie Doug is offline
Old 04-23-2003 | 05:27 AM
Re-consider......
Go Whipple...
TROUBLE MAKER is offline
Old 04-23-2003 | 08:11 AM
mcollinstn's Avatar
Sheesh, guys..
He can probably find a good pair of M1 intercooled procharger setups for less than 3 grand for both (including fuel pumps and regulators).
If he runs around 3 to 3.5 pounds of boost, he'll be sitting pretty.
No need to spend 5 grand MORE for some fabulous Whipples. Remember, these are just 330's. He's looking to conserve dollars, or he'd be asking what to put on his HP500's.
mcollinstn is offline
Old 04-23-2003 | 12:03 PM
blown1500
I have to go with mcollinstn on this one. The Whipples might be better, but here, the money isjust not worth it. I would spend the difference on pistons if I did anything else.
Old 04-23-2003 | 12:28 PM
bsag's Avatar
VORTECH ALL THE WAY!
bsag is offline
Old 04-23-2003 | 02:45 PM
Originally posted by mcollinstn
Sheesh, guys..
No need to spend 5 grand MORE for some fabulous Whipples. Remember, these are just 330's. He's looking to conserve dollars, or he's be asking what to put on his HP500's.
mcollinstn...you hit the nail on the head, im not pushing that one is better than the other, in fact that would be a mute point, but yes ive also seen them reasonable in the past and just could not make a move at the time, now i can and would like do so and run conserve just to get by for now, id rather have the good stuff for sure, but this what i can do for now, im not dead locked on procharger, just somthing that is small front mounted, thanks for all the comments keep them coming if you will, thanks nick
baja27
07-31-2006 08:21 PM
BY U BOY
08-09-2005 04:10 PM
baja27
2
04-16-2004 10:10 AM
Freekazz
7
02-11-2004 10:04 AM
Red 230sx
0
10-17-2003 08:32 AM
