Valve lash?
Old 05-24-2003 | 06:10 PM
seabeach's Avatar
Question Valve lash?
Need some help figuring out what valve lash to use on my engines. I have CBB talldeck, Crane 139651, Hydraulic roller lifters, Crane gold rockers. Have tried Crane homepage but I found 2 answers, 1/2-1 preload and on the camcard zero (0) lash with engine hot. As it is the first time with rollers and this cam I wonder whats the correct way to do it?
/Torbjorn
seabeach is offline
Old 05-24-2003 | 06:26 PM
bobby daniels
I think I would go 3/4 turn to be safe and you should be in good shape
Old 05-24-2003 | 07:00 PM
Pwrbt33's Avatar
Talking lashing out ...
I agree with Bobby D., once you find zero lash go 3/4 and lock down the poly lock, then torque the nut to 26-28 ft.lbs.
If you need any other help feel free to call the shop.
Pwrbt33
Offshore Performance
410-827-0200 x-1
Pwrbt33 is offline
Old 05-24-2003 | 08:38 PM
Elite Marine's Avatar
Having been through hell and back troubleshooting a recent rebuild problem. Many of the builders, shops and manufacturers have been recommending 1-1/2 turns. Is this too much? I've been informed that this is what a few Nascar teams are doing.
Elite Marine is offline
Old 05-24-2003 | 08:43 PM
bobby daniels
nope nascar uses solid flat tappets hyd rollers would never live in that enviroment (9500+ rpm's),,Also I really have found 1and a half is to tight ,but would work
Hows your new motor 650 ???
Old 05-25-2003 | 01:26 PM
Engine is perfect, thanks for asking, maybe I'll back them off at my next oil change. I'll try the 3/4" turn.
Thanks,
Kirk
Old 05-25-2003 | 02:06 PM
seabeach's Avatar
Thanks, 3/4 it will be.
/Torbjorn
seabeach is offline
HARRISONMIRAGE
0
10-19-2004 01:35 AM
HARRISONMIRAGE
2
01-30-2004 10:09 PM
paradigm shift
5
08-25-2003 05:07 PM
Goomba II
4
05-01-2003 08:12 PM
dyno
8
07-17-2002 06:54 AM
