low voltage
Old 06-24-2003 | 06:55 PM
greg hacker
Angry low voltage
with key on 10-11 volts at gauge, 12.5 at batts, new batts,starts slow some times seems like needs tons of power? shut off batt switch charges at 13.5, switch on charges at12.5?accs also make gauge drop 1volt
Old 06-24-2003 | 09:38 PM
Audiofn's Avatar
Charter Member #232
Check for a corroded wire some place. You could have bad starter wire. Make sure your ground is also good. When this happens have you checked voltage at the coil, then the battery and the guage with the SAME meter? You could have voltage drop or you could have a bad guage. Give us as much info as you can and we sould be able to fix this for ya.
Jon
Put your best foot forward!
Audiofn is offline
Old 06-25-2003 | 08:15 PM
greg hacker
gauge is good,starter to batt is good turn on blower and drops to 12 when running , also put in new alternator, could it be the starter
Old 06-25-2003 | 10:00 PM
Turbojack's Avatar
fully charged battery should be 12.7 volts. Motor running voltage should be somewhere around 13.8 volts. Voltage depends on temp. These voltages are at battery. Some volt meter read different so there may be difference there. Where are you checking when you say blower drops to 12? When cranking engine what is battery voltage droping to. Need to check voltage both at battery & starter. If voltage is different then bad cable or cable end. How old is starter? If starter has gotten wet the brushes could be sticking/rusted & keeping the starter from working correctly. Sounds like you have replaced everything except the starter.
Turbojack is offline
Old 06-25-2003 | 10:09 PM
obnoxus's Avatar
Charter Member #1171
Check your grounds. Check for corroded cables. Pull back the insulation a bit, remember to tape it up after.
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Todd Coffelt
06-01-2008 05:30 PM
BadDog
2
05-15-2007 01:44 AM
Prater
9
03-28-2007 05:47 PM
MILD THUNDER
7
10-18-2004 07:40 PM
bigblock
Powerquest
10
09-09-2003 08:11 AM
