Water In Engine Oil >
Water In Engine Oil
Water In Engine Oil
Old 06-15-2004 | 02:33 PM
Angry Water In Engine Oil
I have a friend who has a 93 502 with b&m blower. He had the engine out being dynoed. When he got the engine back, he took off the oil filter and the oil had a milky appearance. He tore down the engine, checked the head gaskets, which were okay. He had a leak down test performed - everything okay. Checked the headers for leaks - no leaks. Any ideas where the water is coming from?
KBUSH1 is offline
Old 06-15-2004 | 05:47 PM
lucky strike's Avatar
Default Re: Water In Engine Oil
intake manifold ??
oil cooler ??
lucky strike is offline
Old 06-15-2004 | 06:18 PM
I had a 502 crack form improper winter storage. The mechanic said they eighter crack in the valley under the intake manifold or down low below the pistons. I would be its craked in one of these palces if leakdown is good. But im no expert,but did learn alot putting new engines in my scarab last summer.Did it ever overheat. The guys dynoing it probably overheated it???????? Why was it getting dynoed anyway?
HOTTZU98 is offline
Old 06-15-2004 | 06:52 PM
offthefront's Avatar
pull the pushrods and do a leakdown with Pistons at BTC ....(Bottom)
offthefront is offline
Old 06-16-2004 | 06:45 AM
Engine Was Out Due To A Broken Starter Plate That Had To Be Welded. So He Had It Dynoed To Check It Out. Pulled The Motor Out And Ran It Without The Oiler Cooler, Or, Headers, And The Same Milky Oil Occured. When Winterizing The Engine, He Could Not Run It, So He Drained The Block And The Headers, And Pulled The Thermostat And Filled With Antifreeze. The Block Should Have Been Full.
KBUSH1 is offline
Dun Canoein
08-12-2006 09:30 PM
tewks
19
07-26-2006 09:11 PM
jeff32
06-28-2006 08:48 AM
Fuhgedaboudit
6
06-13-2004 03:53 PM
Monty
14
01-29-2004 10:59 PM
