Hydraulic Roller Setup for 502 >
Old 03-12-2005 | 01:54 AM
vandeano's Avatar
Default Hydraulic Roller Setup for 502
I have a 1991 502 Mag stock engine with Eddie marine exhaust. I would like to change it over to a Hydraulic Roller setup.
I would really appreciate any advise on which type of roller setup would be good and not have to worry about water reversion with my type of exhaust.
vandeano is offline
Old 03-12-2005 | 07:25 PM
Pat McPherson's Avatar
Default Re: Hydraulic Roller Setup for 502
Most have recommended the Crane 731 or 741 in the past.
If you have the short captain's call type riser then don't go bigger than the 731.
Either way, you should have your heads gone through because of the added lift.
It would not be a bad idea to freshen the whole engine because it's going to make a lot more power...
Patrick
Pat McPherson is offline
Old 03-12-2005 | 07:34 PM
50boat's Avatar
call travis.. he has 2 cams from a hp 500 that are perfict condison 8163804732.. went to 540 cu u-dow-u- do750hp
50boat is offline
BLOWN85
11
04-29-2008 12:08 AM
ghittner
19
05-14-2007 05:36 PM
Sean
19
10-18-2003 03:12 PM
formula31
6
03-19-2002 10:33 PM
