Grand Haven, MI exhaust...
#61
#62
Maybe we should call the Ottawa Co. Sheriff's Dept every day during the summer and tell them we like the sound of the boats or do NOT mind the noise---the call would only take less than one minute. I would think that each positive call should counter each negative call that comes in. Sounds fair to me.
#65
Here is the Michigan Marine safety Act, read rule #8. Here on Lake St Clair the Sheriff Dept has not made it a issue, but at times the DNR has, unlike the Sheriff Dept, I here the DNR dose not need probable cause to come on your boat and look for the cut out !!! [Silent Choice]
#67
That last sentence "A modern device, underwater exhaust system or a system discharging cold water through the exhaust of an inboard engine, each of which is capable of muffling the noise of the exhaust of the engine in a reasonable manner, shall be considered as meeting the requirements of the rule" specifically allows silent choice, so long as there are mufflers on the thru-transom exhaust. Silent choice is a modern device which allows "underwater exhaust system or a system discharging cold water through the exhaust" depending on the position of the switch. Therefore, if the noise of the exhaust of the engine is muffled in a reasonable manner (read: you meet the dB requirements) regardless of the silent choice setting, you're all good.
#69
#70
Marie Havenga of the G.H. trib did write an article () about this problem. I don't think it had much impact. I called or emailed her mid summer after being tested at pigeon lake. She was fired up about being pulled over herself by a part time deputy in the G.H. channel. A week later the article came out. It was objective and fair but lacked the punch needed to start something. In talking to her and others I did learn that the Spring Lake Homeowners Assoc. donated two very expensive decibel meters to the Ottawa Sherriffs dept. Considering large boats have a no wake rule on S.L. sounds like a bad investment. I was moored toward the end of the year at G.H. Muni marina and watched the deputies pull over every boat that came from the wharf and send about 50% back to the blocks. I took pictures of each bust in hopes of using them in some sort of campaign. You would think the people that matter in the town goverment would have a clue about the economic impact after hosting SOTW in the years past. Obviously they are not that bright. Too bad. As a G.H. resident living right on Lake M I can personally vouch for the fact that fastboat traffic in and out G.H. harbor was way down. As a side note most days I wake up at 6:00 AM to the sound of an unmuffled hog as where performance boats are never on the scene until noon or later. As much as I hate to say it I recommend crossing G.H. off your list of destinations until the town fathers and the sheriff wise up which unfortunately will never happen.
http://www.grandhaventribune.com/pai...1529392136.bsp
Cheers,
Marc
Cheers,
Marc
