Go Back  Offshoreonly.com > Owners Forum > Magnum Marine
Lake St Clair Magnum's >
Old 05-15-2008 | 09:44 AM
  #821
beakman's Avatar
Len,
What props you running?
What did the engine synch have to do with power loss??
Rich
beakman is offline
Old 05-15-2008 | 05:00 PM
  #822
Originally Posted by beakman
Len,
Rich
Hey how are you doing, nace to hear from you.
When i got the boat it had 19's on it and still dose for prop size
Im going to look into 23's for it soon
My glenndeny synch system is were i can hit a switch and my left throttle will go all the way down and i can run both moters for the right handle at any speed weather full out or running in the marina. I had the box taken off and un hooked as it was not allowing the slave moter to run wide open... Did a tune up and new fuel filters to see if that would help. had the carbs set up but now he has called me after doing the timing and says that one carb is not letting enough fuel in so looks like im looking a new carbs after this weekend as im going to see how she runs first as im not made of money like some of these guys with brand new Cigs and MTI's worth big bucks on this site. boat should do 62 64mph (right)
Hey do you have any pic's of the boat when you had it as i would love to see them and what rpms did you top out at if you remember
I dont think wolf used the boat that much in the 7 or 8 years that he had it and it had just sat under cover in his well most of the time
Hope to see you in june in lake st clair,
Len S is offline
Old 05-16-2008 | 06:04 AM
  #823
Jammin''s Avatar
Originally Posted by Len S
...after this weekend as im going to see how she runs first as im not made of money like some of these guys with brand new Cigs and MTI's worth big bucks on this site. ...
Yes, but which boat will garner more attention at the dock?
Jammin' is offline
Old 05-16-2008 | 11:14 AM
  #824
hey len,
you may be able to keep the carbs, see if your mechanic can install larger valves or throws (i forget the technical term, im sure someone on here will know) literally like a 2 dollar part. i had some put on mine and it helped deliver more fuel and got rid of some hesitation.
I'd try that first, if that does not solve the problem you may have to get some new carbs with double pumpers as im pretty sure you have single pump right now, that should solve the problem and could possibly squeeze another mph or two out of her.
Cigret1 is offline
Old 05-17-2008 | 05:41 AM
  #825
nocigarette's Avatar
I think it is kind of odd that a mechanic would be asking a customer where to set timing on a small block.....
nocigarette is offline
Old 05-18-2008 | 08:40 PM
  #826
Heys guys,
We got the boat in the water today as it's our long weekend here on the other side of the river and the boat is runnng great.
Got everything set as far as the timming, and the tune up and just said f_ck it and went ahead and had him put the new carbs on after all.. and got a big bill, Mabey i can get a part time job at tim horton.. ha ha.. lol lol
Cool out today on the river and on lake huron.
Hope everyone has a great season.
Len
Len S is offline
Old 05-18-2008 | 10:51 PM
  #827
h2oboater's Avatar
W.N.W at 20mph winds today on Lake St Clair = MAGNUM WATER. Tomorrow up to 30mph = BIG MAGNUM WATER !!!
Len good to hear your up and running, how much is fuel now in Canada ?
h2oboater is offline
Old 05-18-2008 | 11:14 PM
  #828
Hey mark, Ya its been pretty cool this weekend weather wise here up by the bridge...
Gas today in Sarnia Ontario Canada was $1.30 how about in your neck of the woods??????
Len S is offline
Old 05-19-2008 | 12:41 AM
  #829
h2oboater's Avatar
On the road $3.89 reg, at the marinas on the Salt River $4.60 per gallon ! That would make your gas costing around $4.92 US gallon ?
Old 05-19-2008 | 06:28 PM
  #830
beakman's Avatar
Default len
Len,
Definately switch to the 23 Mirages. In the spring with cold water I could turn 5400-5500 and get mid 60's all day long.
Hot weather maybe 5000-5200.. 62 mph. That was with fresh motors and a painted bottom. The Mirages settled the boat down quite a bit better than the 3 bladed cleavers that came with it. I would also have to really trim it out to the edge to get max mph.
I got pix's but I thought you were selling?? Didn't want to send if you getting rid of boat.
I got a set of 23's on my Fountain.. If your up in June we'll go to the shallows and switch for a test run..
The advance was just like Mark said 34-36 degrees.
i think your under propped and not getting the max out of that boat.
Rich
beakman is offline
