Bad Kitty,  making things happen. >
Old 09-02-2025 | 04:30 PM
  #171
Craney's Avatar
How much more can you take
before you switch to outboards.
Craney is offline
Old 09-02-2025 | 06:04 PM
  #172
Originally Posted by ICDEDPPL
I've blown plenty of motors, never a trans. Probably just jinxed myself.
That is an interesting engine set up,
What you got going on there?
😩 you called it, if anyone can get that turned around you’ll do it in record time. Good luck!
swellcraftman is offline
Old 09-03-2025 | 06:37 AM
  #173
CNC's Avatar
CNC
Interesting....Welcome to my world....warned you
CNC is offline
Old 09-03-2025 | 08:35 AM
  #174
Rebulit kit and all new clutches and steels $500
plus you tube video, I`ll have this back together by the end of the week.
I`d like to kiss whomever at Nortech designed the rear opening to get a trans out without having to pull the motor.
ICDEDPPL is offline
Old 09-03-2025 | 08:36 AM
  #175
what`s the warning again?
ICDEDPPL is offline
Old 09-03-2025 | 08:37 AM
  #176
Talking
Originally Posted by pasquesi
You poor bastard......been a rough 2 years for you! Sorry man.
I got to run it for a whole 15 minutes!
ICDEDPPL is offline
Old 09-03-2025 | 09:41 AM
  #177
Veteran: Navy
Which lake around San Antonio
your busy bee
powerboatr is offline
Old 09-03-2025 | 11:36 AM
  #178
CNC's Avatar
CNC
I guess I asked, because mine went out, First time getting on plane with refreshed motors. Which YouTube video did you use?
CNC is offline
Old 09-03-2025 | 03:57 PM
  #179
One thing about these 3600 Supercats is my shift cable bracket is attached to the driveshaft cover.
Double R had a case where a customer went thru 4 transmissions in a short time.
Couldn`t figure it out so they set up a Go pro in the bilge. In a turn the cover would flex and just pull it out of gear , once that happens the trans ****s the bed instantly.
I had 3 out of 4 screws in the cover and one was stripped.. the trans burned out in a turn.
So now I will always make sure that cover is tight with back up nuts.
The cluches don`t look too bad, for whatever reason all the fluid went out the front seal into bellhousing but seal looked fine .. don`t make much sense.
These were rebuilt by Bam to 1300 in 2020 with very little time on them.
This is the reassembly video but he has dissasembly also.
ICDEDPPL is offline
Old 09-16-2025 | 10:27 AM
  #180
Got some new props, did some running this weekend.
Had an oil leak at Thermofilter so didn`t open her up .. new parts ordered .
