Bad Kitty,  making things happen. >
Old 01-12-2026 | 06:20 PM
  #241
I`ve struggled with dip sticks and leaking thru out the years.
I`m going to try something diffferent this time around.
Modified Moroso locking dip sticks.
I`m hoping for no more leaks.
ICDEDPPL is offline
Old 01-13-2026 | 08:31 AM
  #242
Active Streak: 30 Days
Leaking at the block or out the tube on top? That sounds like you have too much pressure building up in the crankcase, maybe?
Helmwurst is offline
Old 01-13-2026 | 09:49 AM
  #243
There`s always crankcase pressure on a blown engine.
The crank whips oil in the tube and the pressure takes it out the top.
ICDEDPPL is offline
Old 01-13-2026 | 10:37 AM
  #244
The crank whips oil in the tube and the pressure takes it out the top.[/QUOTE]
From that you have internal crankcase pressure. All engines have it and more so with turbos or blower engines. To ways to fix that and not put a bandaid on it are better, or more breathers. Better yet a vaccum pump or dry sump system would solve the pressure issue for good. I got (4) breathers on my BBCs with Whipples and a 6 stage dry sump system on the LS with a Whipple.
LakeBoat4 is offline
Old 01-13-2026 | 05:50 PM
  #245
Vacuum pump and dry sump would definitely do the trick but at a cost and added complexity.Would be hard to incorporate now.
I had -6An lines going to a catch can and the breather only had a 1/2" opening .
Upgraded to -12AN and 1" opening
ICDEDPPL is offline
Old 01-13-2026 | 07:57 PM
  #246
That is a good upgrade. I would suggest (2) 12 an lines to the catch can. One from each valve cover. Then a 1 inch opening or larger to mount a bigger filter on. It is not that much to do a Moroso Vaccum pump and a longer belt to your system to drive it. Think they still make them. It will acually add HP too. This was done to my SS Hemi car and saw 30-35 HP gain.
Old 01-14-2026 | 03:48 AM
  #247
Craney's Avatar
Look at the picture above your post
Craney is offline
Old 01-14-2026 | 10:43 AM
  #248
Look at the picture above your post[/QUOTE]
I did so whats your Point? Instead of Help someone you Criticize, maybe an ego issue, Bro...
Looks like (1) 12 an, the other hose looks smaller. The tank exit still looks like it is small and stepped up at breather, a restriction. Going back a few post and "reading" there is positive crankcase pressure causing the problem. I'm pointing out the fix not critical of a photo.
Old 01-14-2026 | 11:28 AM
  #249
Easy buddy.
The picture shows two -12AN one from each valve cover and a -20AN breather, which is 1' I believe .
The description is:
ICDEDPPL is offline
Old 01-14-2026 | 11:35 AM
  #250
I`m open to ideas but vacuum pumps on blown marine engines don`t make sense.
What a vacuum pump actually does
A crankcase vacuum pump:
  • Pulls vacuum in the crankcase
  • Improves ring seal
  • Reduces windage losses
  • Can add small horsepower gains in NA or race-only engines
This works best when the engine naturally builds crankcase pressure that you can evacuate consistently.
Why it doesn’t play well with a blower (especially marine)
1. Blowers already complicate crankcase pressure
A supercharged engine:
  • Has higher cylinder pressure
  • Pushes more blow-by past the rings
  • Often uses looser ring gaps for heat
A vacuum pump has to work much harder just to keep up — and often can’t maintain stable vacuum under boost.
2. Marine engines live at steady load
Unlike cars:
  • Boats run long periods at high RPM and high load
  • Oil temps stay elevated
  • Moisture management matters more
Vacuum pumps:
  • Pull oil mist aggressively
  • Can dry out seals
  • Increase oil aeration issues over long runs
This is a durability problem in marine use.
A vacuum pump system adds:
  • More fittings
  • More hoses
  • More failure point
4. Minimal gain vs real risk
On a blown engine, realistic gains are:
  • 0–5 hp at best
  • Often no measurable gain
Versus:
  • Added complexity
  • More maintenance
  • Higher chance of oiling issues
In a boat, that tradeoff almost never makes sense.
When it might make sense (rare cases)
A vacuum pump can make sense only if:
  • It’s a race-only marine engine
  • Short run times (drag boat, shootout boat)
  • Dry sump system
  • Tight control over oil scavenging
  • Professional-level setup and maintenance
Even then, many builders skip it.
Better alternatives for blown marine engines
If the goal is reliability and performance:
Proper crankcase ventilation
  • Boost-referenced breathers
  • Large-diameter vents
  • Proper oil separation
Quality ring package
  • Blower-specific rings
  • Correct end gaps
Oil control
  • Good windage tray
  • Proper oil level
  • Marine-rated separators
Dry sump (if extreme)
  • Far better solution than a vacuum pump
  • Proven in high-output marine builds
Bottom line
For 99% of blown marine engines:
A vacuum pump adds risk with almost no reward.
ICDEDPPL is offline
